Intermitent Tachometer
Old Jul 1, 2021 | 04:35 PM
Jim4924's Avatar
Jim4924
Default Intermitent Tachometer
My tach doesn't start working until I'm 5-6 miles down the road. It seems to start working when the motor is warmed up. I realize its electronic, not vacuum or anything else. Does anyone have any suggestions of what the problem is?
Thanks,
Jim
Old Jul 1, 2021 | 06:00 PM
BKarol's Avatar
BKarol
Bypass the tach filter. Run the tach wire directly into the distributor. At least eliminate this first as being the problem and the easiest.
Old Jul 4, 2021 | 02:48 PM
bschuus's Avatar
bschuus
Mine does the same thing from time to time. I will also remove the tach filter for a try
Old Jul 5, 2021 | 03:18 PM
Jim4924's Avatar
Jim4924
I'll try that, Thanks!
Old Jul 6, 2021 | 01:16 AM
7T1vette's Avatar
7T1vette
Might also be a foil 'fracture' on the circuit board which 'makes' or 'breaks' as temperature changes.
Old Jul 6, 2021 | 02:24 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I saw an article about the Ignition module in HEI Distributors causing irregular tach readings when it gets too hot. (?)
Old Jul 6, 2021 | 07:51 AM
interpon's Avatar
interpon
I am betting board bad.. i read a lot of articles and advice , although a great test to remove filter..it seems to always see board issue..
Old Jul 6, 2021 | 08:54 PM
7T1vette's Avatar
7T1vette
But if it reads correctly some of the time, it's not a defective component. If so, it would not read at all or not read correctly when it was operating. That's why I think it is a simple continuity break somewhere in the system: 1) a fatigue crack thru a single foil trace on the tach circuit board; 2) an intermittent tach filter; 3) tach signal wire with a break in the run or a bad connection at a terminal; etc, etc. I'm just suggesting that you try to identify simple fixes before you dump ca$h at the problem.
Good luck.
Old Jul 6, 2021 | 09:31 PM
interpon's Avatar
interpon
Good luck.
other than trying filter or not… i am staying board…cheap enough
https://www.corvetteforum.com/forums...-question.html
and easy to replace
To Intermitent Tachometer
