Brakes
Old Jul 24, 2021 | 06:10 PM
1973bluevettee's Avatar
1973bluevettee
Default Brakes
I have a 1973 corvette 350 with the stock brakes and I’m getting a new master cylinder how do I know if I need deep or shallow pocket and what bore do I need.
Old Jul 24, 2021 | 08:36 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The bore size is only dependent on power vs. manual brakes. The power master cylinder is a larger bore; manual smaller bore. Buy the one spec'd for what you have. Same with the plunger rod depth - buy master spec'd to your year and brake setup. There is some adjustability on some power brake rods (not sure about manual brakes) but you need to be able to measure the depth of the cylinder's piston "pocket" and compare it to the projection on the power brake booster. There is a relatively inexpensive gauge to do this about $10.
Old Jul 25, 2021 | 05:27 AM
7T1vette's Avatar
7T1vette
Yep. The push rod needs to be the same length as the pocket in which it fits. If the rod is too short, there is extra 'slop' in the pedal before the brakes start to apply. If the rod is too long, there is NO slop in the pedal before brakes are applied. Neither is a good situation.
To Brakes
