Radiator removal
Old Aug 3, 2021 | 09:05 PM
7t5's Avatar
7t5
St. Jude Donor '14
Originally Posted by L-46man
I've written about foam seals a couple of times....the biggest GOT TO DO IT! is the lower seal/foam support that supports the entire weight of the radiator on the bottom pan.
Get a dense semi compressible foam strip, end to end....glue it down!
Unkahal
Wow good info.
What is a good source for this foam? Approximate dimensions for width and thickness?
Maybe like this? It comes in 2" wide as well.
Neoprene Foam Strip Roll by Dualplex, 1" Wide x 10' Long x 1/4" Thick, Weather Seal High Density Stripping Non Adhesive – Weather Strip Roll Insulation Foam Strips - 10 Feet Long - - Amazon.com Neoprene Foam Strip Roll by Dualplex, 1" Wide x 10' Long x 1/4" Thick, Weather Seal High Density Stripping Non Adhesive – Weather Strip Roll Insulation Foam Strips - 10 Feet Long - - Amazon.com
Old Aug 3, 2021 | 10:00 PM
Larry Lowe's Avatar
Larry Lowe
6th Gear
Originally Posted by BKbroiler
This is how I've done it on my 77.
Remove the hood. (2 man job) Mark the hinge locations on the hood first.
Disconnect hoses and trans cooler lines.
Unbolt radiator support by removing bolts in both front wheel wells
Remove radiator restraints at top of radiator
Remove engine fan
Tilt rad support, rad and shroud forward (toward front of car)
Lift out radiator and shroud at the same time.
No shroud cutting or pounding required.
I just finished my radiator swap and used this method. I also loosed the two bolts on the bottom of the radiator support(under the car). Lots of small adjustments and tugging to get the shroud out without damage.
Good luck!
Old Nov 26, 2021 | 09:04 PM
Z51JEFF's Avatar
Z51JEFF
Originally Posted by 7t5
I have been on youtube looking for a decent video for radiator removal. I have a 1975 l48, no air, automatic.
The videos I find are absolutely horrible. To the point that I would be embarrassed to post this stuff. I really want to see the hood coming off and the shroud coming out, but 3 videos in a row just skip right over those parts.
Does anyone have a decent video they can recommend? Or any tips and tricks?
I wish I had a real video camera so I could make something watchable for others.
Some are just a complete disservice to those looking for the info. Step by step videos are greatly appreciated but leaving out major parts of the job is just bullshit.
