I have been on youtube looking for a decent video for radiator removal. I have a 1975 l48, no air, automatic.
The videos I find are absolutely horrible. To the point that I would be embarrassed to post this stuff. I really want to see the hood coming off and the shroud coming out, but 3 videos in a row just skip right over those parts.
Does anyone have a decent video they can recommend? Or any tips and tricks?
I wish I had a real video camera so I could make something watchable for others.
On my 70 the hood does not have to be removed. You have to remove the fan, upper and lower rad hoses and the shroud. 70 has a plastic fan shroud that is secured with 2 studs on the bottom and a bracket on the top. Getting the should out can be difficult. If I recall the trick is to remove the upper rad brackets (2). and move the top of the radiator forward as far as possible and pull the shroud on the driver side and get it to clear the upper control arm. Once the left side is clear the right side can be removed. If i recall the lower rad hose is removed after the shroud is out of the car.
I was in the same spot about a year ago. The hood is easy with 2 people but doable by yourself. Just use a lot of blankets. The shroud is the hardest part of the job. Most guys say you have to cut the shroud to get it out, or pull the upper control arms. Not doing either of these steps. I used my engine hoist to lift a little in the center of the shroud....with pressure on I used a big rubber mallot to pound it up a little on both sides. Put a little more pressure lifting and pounded it up a little more. The hard part was getting it past the control arms but surprisingly the shroud lifted past them and out it came. I thought the shroud was gonna break but I took it slow and it came right out. I pounded it back in the same way.
To get the radiator out you just lift the driver side up a little so it's at an angle and it will lift right out. Be careful of the drain petcock. I went to drain it and all I wanted to do is crack it open and the situate my tub. Well the whole thing tore out of the radiator and I wore a lot of coolant in a hurry.
This is how I've done it on my 77.
Remove the hood. (2 man job) Mark the hinge locations on the hood first.
Disconnect hoses and trans cooler lines.
Unbolt radiator support by removing bolts in both front wheel wells
Remove radiator restraints at top of radiator
Remove engine fan
Tilt rad support, rad and shroud forward (toward front of car)
Lift out radiator and shroud at the same time.
You got a good camera on your phone? Content is King! I do all kinds of stuff for my own amusement or try diff things to keep making videos interesting for me.
Lots of peeps use phones even Cleetus sometimes, I don't have a smartphone or I'd prob give it a shot. I've been using an old crappy camera and only recently bought a vloggy type one(still kinda prefer my old camera). Not used it yet tho but I've been busy.
Anyways my 77 that had AC needed the entire shroud removed. I rem thinking how stupid that was compared to other cars but I don't see why yah need to remove the hood for just the radiator, maybe AC condenser but I just cut mine out LOL
Did my '75 with hood on. Shrouding needs removed. Other than that, just like any other car. Move it if its in your way. Just be patient and take your time.
Perhaps this TheCorvetteBen video. He has several others. I was able to remove my hood by myself using ropes slung from my exposed ceiling studs. Having a helper would be preferable, though.
Remove engine fan
No shroud cutting or pounding required.
I am going to try this method first.
Thanks everyone for the tips. I am likely not going to make a video because it would be just as bad as the other content I have viewed on YT.
Remove engine fan
I swapped out the original rad and fan on my 79 for a DeWitts aluminum rad with electric fans. Although I didn't remove the hood. I pretty much followed broilers steps, but I just took out the top 2 bolts of the core support in the wheel wells and left the bottom ones loose. There was also a brace on the bottom center of the core support that has to removed then tilt the rad to almost a vertical position to get it out. Since I was installing electric fans I didn't have to worry about reinstalling the shroud and fan. Did it on a Sunday with the help of my next door neighbors teenage son.
Have had the radiator in our 75 L48 auto air out two times, left the hood on. Wife helped both times, no problems.
I did split the shroud at the bottom the second time.
I hope to leave the shroud intact. Was that purposeful or accidental?
Intentional, I'm sure. It makes no sense to fight with it more than once!!! (been there, done that....)
Yep, for sure. I made three cuts to make reinstalling and fastening the shroud a simple thing,, and concealing the re-attachment points was easy. DONT FIGHT IT,, CUT IT.
I’ve done this twice in the last year... (hopefully you bought a quality rad)
I have a 79. Didnt remove the hood, remove rad hoses and fan. Removed top radiator clamps/brackets. Loosened the fan shroud as i couldnt get it out, just moved it up close to the front of the engine. Then when pulling the rad, the passenger side hose outlet can get caught up, so i carefully wrestled it 90* so the driver side tank was facing the hood/sky. Then pulled it out. Same thing for install, in reverse.
It can be tricky during the removal part, and getting that bottom hose outlet clear of everything, it was a lot easier with my dad helping with a second pair of hands to hold the weight of the rad while I steered it out. Was able to do it myself the second time cuz I had a general idea of how to get it out.
Make sure your support to rad foam seals are in good condition or order a set of replacements. Iinstalling a rad without good seals will cause overheating problems.
I've written about foam seals a couple of times....the biggest GOT TO DO IT! is the lower seal/foam support that supports the entire weight of the radiator on the bottom pan.
Get a dense semi compressible foam strip, end to end....glue it down!
My buddy on these forums just recently bought a 74 'Vert.. "Hey Unkahal, the previous owner has a receipt for a new radiator, yet it's leaking from the underside".
Me; " wanna bet that the foam seal was not replaced and or was perished and the 'CORVETTE SHOP' (oxymoron) just chucked the rad in there without understanding the system".
Sure enough, Drv's side header tank worn thru in short time by lower pan support. New radiator time!
The foam surrounds are SUPER IMPORTANT!
While it is true you don't have to remove the hood for this job....I find it EASIER if you do. I mark assiduously (now forever) the upper hood hinges and the hood goes back as exactly as it left!
