A little feedback please!!
Old Sep 14, 2021 | 03:08 PM
JavaJolt78's Avatar
JavaJolt78
Default A little feedback please!!
Hello all of my C3 gurus!!!
I could use a little feedback with regards to my 78 coupe...
I have owned it for about 11 years and have changed all fluids from time to time but never thought much about the power steering unit..
My thoughts are to suction out the fluid and top it off with a good PS fluid..
If that sounds like an easy job for me all I need to know is what type/brand of PS fluid should I use??
In advance thanks for all your feedback!
JJ78
Old Sep 14, 2021 | 03:16 PM
Mark G's Avatar
Mark G
Start with that. Suck old fluid out, install new, and repeat a couple more times.
When I buy a vehicle that has some miles, ..I remove the return line and hook a section of clear hose to it, into a white plastic pail (and plug the nipple on the p/s pump). Then fill the pump and have a helper start the vehicle. Have a qt of new fluid ready to go with a funnel and pour it in as fast as you can till the fluid in the return hose runs 'clear'. Sometimes ya have to shut the vehicle off/refill because it may pump out faster than you can pour it in, depending on your funnel (don't run it dry). Then you know you have exchanged all the fluid.
Of course the suction gun method works too, and it's a lot easier.
Old Sep 14, 2021 | 03:57 PM
JavaJolt78's Avatar
JavaJolt78
Tx Mark G,
Sounds like an easier way to do it....
So you are saying to suck out the old fluid and install new fluid and remove the new and refill at least 3 times??
Can you offer what is the best PS fluid to use?
No probs with cost bc I work for Advance Auto..
Considering the placement of the pump underneath the alternator would it be wise to disconnect it and move it out of the way??
JJ78
Old Sep 14, 2021 | 06:24 PM
interpon's Avatar
interpon
Originally Posted by JavaJolt78
Tx Mark G,
JJ78
I would buy a pump from advance auto and get the GM power steering fluid
Old Sep 15, 2021 | 07:42 AM
JavaJolt78's Avatar
JavaJolt78
Are you saying to buy a new PS pump instead of R&R'ing the old fluid???
JJ78
Old Sep 15, 2021 | 09:13 AM
interpon's Avatar
interpon
JJ78
NO! never.. a pump to suck out the fluid.. a good one from your store.. and gm the GM fluid
here is a few posts
http://jimshea.corvettefaq.com/?cat=5
https://www.corvetteforum.com/forums...leak-79-a.html
Amazon Amazon
Old Sep 15, 2021 | 09:20 AM
JavaJolt78's Avatar
JavaJolt78
here is a few posts
https://www.amazon.com/Genuine-GM-Fl...1711551&sr=8-5
Tx so much for the info!!
JJ78
To A little feedback please!!
