1981 Corvette
Old Sep 14, 2021 | 08:51 PM
thelal1's Avatar
thelal1
Default 1981 Corvette
What is the actual top speed of a 1981 corvette if you change speedometer to a.140 conversion
Old Sep 15, 2021 | 01:05 AM
Bikespace's Avatar
Bikespace
The glib answer is 140 mph, while stock it's only 85. I'm not aware of any speed-limiting function in an 81 Corvette. Is that what you are asking?
You may need to change the driven gear that plugs into the transmission, too, but I'm not sure. If you download a speedometer app, you can use the GPS on your phone to give you accurate speed.
Old Sep 15, 2021 | 05:59 AM
7T1vette's Avatar
7T1vette
The 'top speed' of a 1981 C3 with the 140 mph speedometer is the same as that with an 85 mph speedometer.....
But with the 140 mph speedo, you know how fast you are actually going.
Old Sep 15, 2021 | 06:42 AM
derekderek's Avatar
derekderek
it isn't a hell of a lot more than 85 anyway...
Old Sep 15, 2021 | 07:54 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
About 120 MPH if you have the 45 seconds it takes to get there.......it feels like forever.....and if you have one that the *** end is sagging or the front is too high, the steering will start to float around 120...which is your cue to slow down LOL!
Jebby
Old Sep 15, 2021 | 02:01 PM
LU8's Avatar
LU8
Going by road test data, around 125 mph. Can vary depending on diff ratio and gearbox chosen.
Old Sep 15, 2021 | 02:49 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I would just change it to 250mph, then you could keep up with most other exotics with no problem. I should change mine, it pegs at 85mph, but somehow I go faster, Mmmm...
Old Sep 15, 2021 | 05:20 PM
L-46man's Avatar
L-46man
Default I agree with Jebby...AGAIN
Jebby
About 120 mph. We don't know miles/compression /attitude/altitude/octane/ state of tune....It's a CRAPSHOOT
However, if you can get to 120, no matter how long it takes....be happy with that L-81
Unkahal
Old Sep 15, 2021 | 09:59 PM
7T1vette's Avatar
7T1vette
If you only watch the metric speed scale, it will seem like it is going much faster!
To 1981 Corvette
