Engine and trans combo advice
I also saw this engine/trans combo which looked interesting https://www.monstertransmission.com/...l#.YUo31WZKhmA
Thats far too complex for me to ship over to the UK and install myself, I just want a simple like for like upgrade
Wish you luck. Maybe do some searching via Euro salvage yards for a wrecked C2 or C3 with usable drivetrain....or maybe a later model Camaro or Firebird?
Aluminum heads will allow you to run lower octane fuel with a larger advance and higher compression without pinging at the same compression as a cast iron head. Plus the weight savings. Off the shelf they will flow better than stock heads for a gen 1 small block as well. IF you can find a builder over there that has access to american parts I would have one spec'd out to see what the cost is versus having a crate motor shipped. If its the same cost to go bigger go with 400 hp, and 400 ft/lbs. You may have to save up for an overdrive transmission later on down the road.
The other solution is swapping in something thats common over there like something out of a BMW or Mercedes.
You need to measure the current rear gear. It is the total combo that counts.
That is a pretty mild engine. Should run strong though. I would contact them and maybe consider one just one step stronger. What is nice is they match the torque convertor to it.
Questions to ask yourself:
Do you want to run regular gas or high test?
Is it all city driving or do you get on the highway?
Looking for 0-60 or 30-90 mph power?
How much of a idle lope do you want?
Do you have enough room for 6000 rpm pulls in say 2nd gear? (could be 80 mph)
I (maybe) like this one better:
https://www.monstertransmission.com/...l#.YUs5u7hKg2w
Get the aluminum edelbrock heads.
Don't you already have efi?
You can delete the carb and fuel pump.
But that one would need premium gas.
Assume by the time its in your car and running you may have up to 50hp less. So if you think you want 300 order 350 etc.
A good 350rwhp should make 400+lbs torque, be driveable sound good and still be able to bring a smile to your face. No need for anything radical to get there just good heads and a moderate cam.
Make sure and get the appropriate stall converter...most guys for some reason think a stock one is the way to go with a cammed up car its the polar opposite.
That will launch you outta the hole if you nail it, normal driving it feels...normal.
https://www.gmperformancemotor.com/parts/19420881.html
*edit ... it comes with a decent windage tray as well. Its pan will fit C3 but it's sump is a little low. JMO, but it'd be worth while to fit a RoadRace pan w/ Right & Left doors. YMMV.
That one is a great deal! 350HP is a great sweet spot for a very nice running SBC. The one above from GM is brand new and has the nice vortec heads with a nice mild long living roller cam.And for a Corvette you need the specific short water pump, C3 specific oil pan, and a not too high intake anyway. Crate engines do not usually come with the versions that fit C3s.
And for the money you are going to spend for a new trans, why not just put a stick in it for the same amount of money? It all bolts in, and you'll be happier in the long run. The only hard part is pulling the dash panel to add the clutch pedal box. And you put in gauges so you can do that!
