Vacuum gauge question??
Old Oct 5, 2021 | 12:36 PM
69_Shark's Avatar
69_Shark
Default Vacuum gauge question??
Hey all,
Quick Question . . . . . .
I need to buy a Vacuum Gauge. I've never had one. No idea if they are all kind of the same or some better than others. I am looking for suggestions. I do not want junk. I do want quality but realistically don't need professional or super high end.
My immediate use is I need to test the vacuum from my LS7 to see if I can support brakes AND headlight functionality. I've been told my assumptions are incorrect and the best way is to simply test the vacuum.
So, anyone here that can point to a decent gauge on Amazon, I'd appreciate it!
They pop up at around 18-35 bucks which seems reasonable. I'm happy to step up to the more expensive one if there is predicted future uses or if the quality requires it! If the 18 bucks one is perfectly fine I am good with that also!
Thanks for any input! I appreciate the guidance!
This one seems well rated and lots selected it. Not stuck on this one, just liked the ratings.
Amazon Amazon
Scott
Popular Reply
Oct 5, 2021, 05:57 PM
Mooser's Avatar
Mooser
It was one of these
Made a new face for it in adobe illustrator and used a needle from another oil pressure gauge I had then an angled bracket to hold it where the clock was... A fair amount of screwing around but, well why not
M
Old Oct 5, 2021 | 12:47 PM
1Hotrodz's Avatar
1Hotrodz
That is a good quality gauge. OTC is a reputable company. It's also a pressure gauge (15PSI). Go for it.
I have a old "crapsman" (craftsman) vac. gauge that about 45 years old and still works.
Old Oct 5, 2021 | 12:56 PM
L-46man's Avatar
L-46man
I have a vacuum gauge in every car since the 70's. I call it "looking into your lover's eyes" lol.
1. Determine diameter I recall that 2 1/16th is standard and they also have 'miniature sizes' such as 1.5" Dia.
2. Then you want a 'fluid filled' gauge...they last longer and the vibrat-ey excursions are damped out (JEGS/SUMMIT)
3. Mounting bracket config.
4. Piping....you want relatively thick walled flexible tubing...thicker the wall the better.
5. You want to 'Tee off' of manifold vacuum as close to the source as possible. Be careful of 'tiny T's'...again the vacuum propagates at the speed of sound...keep the 'bores' open.
Good luck learning your lover!
Unkahal
Old Oct 5, 2021 | 01:20 PM
69_Shark's Avatar
69_Shark
I appreciate the quick input!
It will arrive soon!
I look forward to seeing if I lose pressure to much when I apply the brakes!
Scott
Old Oct 5, 2021 | 01:26 PM
69_Shark's Avatar
69_Shark
Unkahal
LOL!
I already do that with my boosted ford. LOL! I added a permanent gauge just to watch the turbos! ford was to cheap to provide one in my PU! Or rather . . . I was to cheap to spend 75K on the more expensive truck with that gauge!
It is my first and only rig with a fixed vacuum gauge though!
Scott
Old Oct 5, 2021 | 03:33 PM
Mooser's Avatar
Mooser
With much screwing around I managed to get one of the autogauge ones to blend into the stock gauges where the clock used to be
I've got several for setting the engine up and I usually never worry about the numbers (accuracy) as much as which way the needle is moving and when. This one is probably the only one I have that is actually accurate, I should check it to the others someday
M
Old Oct 5, 2021 | 05:40 PM
L-46man's Avatar
L-46man
Mooser-Baby! Great job.... I had to look TWICE!
Dish on which gauge that was! (link)
THX UNKAHAL
Old Oct 5, 2021 | 05:57 PM
L-46man's Avatar
L-46man
Nice usable table here!
https://d2culxnxbccemt.cloudfront.ne...cuum-image.png
Unk
Mooser's Avatar
Mooser
It was one of these
M
Old Oct 5, 2021 | 06:00 PM
L-46man's Avatar
L-46man
Damn! You're ****! lol...but well worth it....super job! The gauge that Chevy shoulda, coulda, woulda!
unk
Old Oct 6, 2021 | 12:51 AM
7T1vette's Avatar
7T1vette
Harbor Freight has them...as do many auto parts stores. E-bay, amazon, etc. etc. Vacuum gauge is very useful for diagnosing Internal combustion engine performance...and for diagnosing vacuum system issues. Read up on how to use it and how to 'read' it. The action of the needle movement is more important than the vacuum level showing on the dial.
Old Oct 10, 2021 | 09:25 AM
Elcransonator's Avatar
Elcransonator
I have a Mityvac and it seems to work ok, plus you can pump the grip to pull a vacuum if necessary.
Old Oct 10, 2021 | 11:22 AM
427L88's Avatar
427L88
8th Gear
M
that looks amazing!!! Any chance you can post the model of the gauge you used?
Old Oct 10, 2021 | 11:31 AM
LS7Vette's Avatar
LS7Vette
M
I’m extremely impressed!!!
Old Oct 10, 2021 | 08:10 PM
Mooser's Avatar
Mooser
Autogage, see post 9
M
Old Oct 10, 2021 | 09:10 PM
Tranz Zam's Avatar
Tranz Zam
I have a cheap Harbor Freight vacuum gauge. I dont use it all that much anymore, as everything I have is now converted to fuel injection, but it has always worked good.
If I was using it every day, I'd definitely get a hood name brand one, but for something just to have tucked away it's fine.
Old Oct 11, 2021 | 06:24 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
I got a Holley one and mounted on the front carb
Old Oct 11, 2021 | 11:10 AM
Mooser's Avatar
Mooser
There's a lot of NICE in that picture right there
M
Old Oct 11, 2021 | 12:14 PM
69_Shark's Avatar
69_Shark
That is a very cool mod!
Scott
To Vacuum gauge question??
