Height without engine
Old Nov 3, 2021 | 05:29 PM
Dusky's Avatar
Dusky
Default Height without engine
Hi guys,
fitted new springs with 1/2 coil cut off because my future engine will have aluminum heads.
but the car sits VERY high.
Combining the springrrate and weight of the engine + trans it would only make the car lower 1-1.5 inch.
Does the car really only lower that little when fitting the engine etc back in, or am I worrying for nothing?
Don't feel like taking the springs out for the millionth time.
Thanks guys
Old Nov 3, 2021 | 06:20 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
In simple terms, if the spring rate is 300 lbs/in per spring and the weight is 600 lbs, the springs, left and right, will compress 1" per spring. Some of that weight will be supported by the rear spring so a bit less than an inch.
Old Nov 4, 2021 | 05:45 AM
Dusky's Avatar
Dusky
That's how I calculated it. I do vaguely remember the suspension ratio to be 0,6 on the cars, so I would need to factor that in. Got some 474 lbs/inch ac delco springs in there (99% sure they're the same as the moog springs).
Old Nov 4, 2021 | 02:02 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You have to drive it and settle the springs in before you can make a decision on the height.....
When I lowered my 69' 427.....it dropped another inch after going around the block.....
Jebby
Old Nov 4, 2021 | 04:34 PM
60 SHARK's Avatar
60 SHARK
To me,, Sounds like your a perfect candidate for Coilovers on the front. No more taking the springs out for the millionth time any more....
Old Nov 4, 2021 | 05:50 PM
Dusky's Avatar
Dusky
I need someone on here to marry me off to their daughter first so I can live in the USA lol.
Not legal in Europe to change to coilovers. Had to sell my yellow vette because I welded in frame reinforcements and welded the bottom arm rails on the sides, go figure...
Old Nov 4, 2021 | 07:35 PM
Richard Daugird's Avatar
Richard Daugird
I'm guessing they have inspectors over there. Do those guys really know what springs/shocks a fifty year old foreign car had stock?
Old Nov 5, 2021 | 06:53 AM
60 SHARK's Avatar
60 SHARK
New topic,,,,, Who would buy it with your modifications, did it have to leave your country, or don't you have to disclose those things to potential buyers,,, I'm just curious.
Old Nov 5, 2021 | 07:42 AM
Dusky's Avatar
Dusky
It depends, my inspector knew the bottom arm rails weren't welded originally, it's a bit the luck of the draw
I sold it to a different country indeed, some countries are better 😅 ( but they pay 2 euros / liter of fuel)
To Height without engine
