Muncie
Old Nov 15, 2021 | 11:49 PM
1973bluevettee's Avatar
1973bluevettee
Default Muncie
I bought a 1964 Muncie m20 to go into my 73 vette. My brother has a 76 vette and put a later Muncie like a 74 Muncie into it without having to change the driveshaft or anything. I thought I read somewhere that my 64 Muncie wont be the same length and match up as my turbo 400 did, does anyone know if this is true or am I going to need a longer driveshaft or??
Old Nov 16, 2021 | 06:59 AM
stingr69's Avatar
stingr69
The driveshaft yoke on the '64 Muncie will be smaller than your existing TH400 yoke. The shifter assembly will probably need to be for a '68. That is the only year C3 that shifter linkage will interchange. The '64 Muncie should have the larger iron front bearing retainer so that helps. '63 is a smaller aluminum retainer.
Hope it has the right tailshaft housing. Speedo outlet sides are different on other GM brands.
That's a start.
My best advise is to stop now and get the right transmission for your year of car. That way you can avoid the struggle, pain and cost of building a mongrell. The right stuff will fit and function properly.
Old Nov 16, 2021 | 08:28 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I believe the 400 is wider and longer than a th350. Other than that you can use the M20. I have had all sorts of years and they are all the same provided they were for the corvette. SO it will fit but the driveshaft may be to short and the splines on the output shaft are going to be different. Auto to manual is never really plug and play, theres always something
Old Dec 12, 2021 | 02:36 AM
1973bluevettee
That's a start.
-I can’t I have already bought the transmission everyone says that Muncies no matter the year if it’s for the corvette there all pretty much the same that’s the reason I bought the one I have because it was the right price. Is there any way I can tell if the Muncie I bought was in fact for corvettes? Sorry I’m new to this probably should have done some more looking before I bought my Muncie….
Old Dec 12, 2021 | 03:12 AM
Sunstroked's Avatar
Sunstroked
There are several differences between a 64 Muncie and the later muncie transmissions. GM kept updating the transmission, ie, more splines on the input and output shafts for strength, also larger diameter, stronger mid case castings. Physically the trans should fit just fine in your 73. But, if you want to put any power to it, it may be in your best interests to buy a later model transmission. Food for thought. I have my 72 m20 in a box that my tremec tko 600 came in. Personally, I like the 5th od gear. But that original muncie is a pretty nice transmission.
Old Dec 12, 2021 | 04:29 PM
Rescue Rogers
run it
Old Dec 12, 2021 | 09:08 PM
1973bluevettee
-if I’m gonna have around 400 naturally aspirated I’ll be fine right?
Old Dec 12, 2021 | 09:32 PM
GTR1999's Avatar
GTR1999
The early Muncies speedo was on the Drivers side, then moved to the passenger so you see if that will be a problem. The 64 has a 7/8 cluster shaft where the later ones, starting 67 if I recall were 1". Diff input spline count so make sure you have the right clutch. Pop the side cover and take a look inside before installing. Check the front of the case at the cluster shaft for oil leaks. Check the slop yoke for grooves.
Muncies aren't a bad street trans but if you start hammering on them with power you will break them.
Old Dec 13, 2021 | 06:10 AM
Rescue Rogers
Yes they were rated above 400 ft/lbs, 400 horsepower. Mine was fine up to 500 hp.No issues
To Muncie
