Spark plugs, fouled?
Old Nov 18, 2021 | 02:56 PM
Mobifire's Avatar
Mobifire
Default Spark plugs, fouled?
69 vette with 406 cb, 70 lt1 cam and intake, holley 600cfm
Delco-R45TS New sparks plugs roughly 400 miles ago, Are they maybe a little rich? I dont know much about how a spark plug should look, especially in older vehicles. I am using lucas octane booster, maybe it contributes to it?
this plug is #2 cylinder, i pulled the #4 and it looks the same.
Old Nov 18, 2021 | 03:09 PM
Tampa Jerry's Avatar
Tampa Jerry
They look good to me. They should be a tan color, which is what I see. Jerry
Old Nov 18, 2021 | 03:25 PM
HeadsU.P.'s Avatar
HeadsU.P.
Glancing at some plug reading charts, it looks one or two notches too cold to me.
Old Nov 18, 2021 | 06:19 PM
interpon's Avatar
interpon
Looks ok to me..i was told a while back that some of those orange colors are additives..
i personnally love NGK equivalent plugs vs china acdelco..
Old Nov 18, 2021 | 08:55 PM
Mobifire's Avatar
Mobifire
Thanks for the replies, i guess i forgot to mention I developed a slight missfire. I just checked ohmage of my wires and found that to be the main issue.
Old Nov 19, 2021 | 12:16 AM
7T1vette's Avatar
7T1vette
What type of ignition do you have? If you have points ignition, you might want to swap in a new condenser and clean/file the points. The condenser is a prime source of misfires when it starts to weaken/fail.
Old Nov 19, 2021 | 06:58 AM
cottoneg's Avatar
cottoneg
I agree with switching to NGK. I used to run different brands. NGK were the only plug I could track the car and not have to change the plugs after. NGK has excellent technical help too. If you call them they can help you find a plug appropriate for your car.
The other advice you received 7T1vette is something to consider. A new rotor and cap will be cheap. Also, I you have an ohm meter, check the resistance of you wires. 40-50 ohms of resistance per foot would mean they are still good.
Old Nov 19, 2021 | 07:13 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Is your vacuum advance hooked to full manifold vacuum?
What is your timing set at....?
That isn't rich but it looks like you need some lead.....
Jebby
Old Nov 19, 2021 | 07:43 AM
cottoneg's Avatar
cottoneg
Jebby
Curious...You mean tetraethyl lead? Not sure where is could be found. Not to mention it is toxic
Old Nov 19, 2021 | 08:24 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No, lead….as in timing lead….advance.
Jebby
Old Nov 19, 2021 | 01:11 PM
Dino_'72's Avatar
Dino_'72
Another vote for NGK. Not sure what type of ignition you have, points or electronic, but some motors are also sensitive to spark plug gap clearances and can cause a misfire type symptom. Had this on a few motors. Looks like you are running a standard .035 gap. Correct?
Old Nov 19, 2021 | 02:32 PM
stingr69's Avatar
stingr69
Looks a lot like octane booster to me. Maybe try some Autolite 26's and better gas and they should look a lot better.
Old Nov 19, 2021 | 08:48 PM
Mobifire's Avatar
Mobifire
The other advice you received 7T1vette is something to consider. A new rotor and cap are cheap. Also, I you have an ohm meter, check the resistance of you wires. 40-50 ohms of resistance per foot would mean they are still good.
I actually just rebuilt my distributor back in may, new cap, rotor, went to pertronix, new coil. Only thing i didnt update were the wires which i just finished up. Dug myself in another hole after i retorqued my starter bolts and the ear on the starter broke. Always something.
Old Nov 20, 2021 | 10:20 PM
7T1vette's Avatar
7T1vette
Lost (or removed) some starter shims??
Old Nov 20, 2021 | 10:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
Agree on the coloring being the booster doesnt hurt anything just a little tougher to read plugs
On the backside of the strap there should be a light colored mark, where is it located?
Old Nov 21, 2021 | 11:34 AM
Mobifire's Avatar
Mobifire
no I kept the shims in, i had to lower the starter to get the chrome plates off for the wires, thinking about buying a rebuilt delco from autozone. Have my original sent out and rebuilt later.
Old Nov 26, 2021 | 06:28 PM
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
That one looks perfectly fine!!!!
To Spark plugs, fouled?
