distributor
Old Nov 22, 2021 | 12:26 AM
Falcon1959's Avatar
Falcon1959
Default distributor
I would like to convert my old distributor on 1971 350 270hp just looking for some advice on what you guys think of the petronix 3 as it looks like to be a great upgrade currently i have a, mild cam , edlbrock, performer manifold, 650 holley double pumper , long tube headers , would just like it to run a littler smother and respond better watched a few videos on the Petronix 3 and really like what i see will it work as far the tack drive is mechanical thank you in advance
Old Nov 22, 2021 | 07:24 AM
sw69vette's Avatar
sw69vette
I installed a Pertronix ignitor set up in my 69 L46 ( 350/350 ) back in 2003 . Have not had any problems with it and it works fine with cable drive tach.
Old Nov 22, 2021 | 07:38 AM
wilcar's Avatar
wilcar
I would leave your points in and if necessary have your distributor rebuilt and recurved. I have blamed my points distributors on several cars in the past as the problem and went to an hei set up only to find that they did not fix my problem. So now I run only points distributors in my 84 carbed C4 and 65 Gto. Just hate to see you spend $$$$ and find out it was not the problem. Make sure that you diagnose other potential problems on your engine before blaming your points.
Old Nov 22, 2021 | 08:17 AM
twinpack's Avatar
twinpack
I have the Pertronix lll with the flame thrower coil. I like i can set the rev limiter. Never had a issue. Benn running 2 seasons now. Running on a 68 L79.
Old Nov 22, 2021 | 09:41 AM
Falcon1959's Avatar
Falcon1959
yes thanks this sound good just to say you installed the petronix 3 module cause i would like to try this but was worried about the mechanical tack drive , i should just leave the set up just the way it is and open my distributor and swap out the part points only the bottom plate were the points sit on did you remove that also i will get the matching coil some say you should run it from the coil to fuse box power wire correct thank you
Old Nov 22, 2021 | 09:56 AM
Falcon1959's Avatar
Falcon1959
Yes I'm planning to try this just to see if it can run smother no harm i can always go back to points i like the feedback an appreciated this is a great site
Old Nov 22, 2021 | 10:22 AM
kodpkd's Avatar
kodpkd
I have the Pertronix. It is comforting to take one thing out of question when tuning the engine. I have researched the HEI, engine tuners say, they don't really add anything to performance.
Old Nov 22, 2021 | 11:59 PM
Falcon1959's Avatar
Falcon1959
Thanks guys for all the input and advice will update this a later date
Old Nov 23, 2021 | 09:34 AM
Tiger Joe's Avatar
Tiger Joe
i have installed the "breakerless SE" ignition in 2 vettes. i know everyone will say no performance gain, but for me in my L79 it helped smooth out my idle. running a petronix in a chevelle without any issues for 5 years.
my dad installed a petronix back in the late 90s in a BBC and its still going strong.
one thing i prefer about the breakerless SE vs the others is it uses the exact same wiring as points, doesnt need a full 12v. so if for some reason it would fail, its incredibly simple to swap points back in. another thing for me is actually finding quality ignition parts in the parts stores anymore.
Old Nov 23, 2021 | 06:52 PM
Falcon1959's Avatar
Falcon1959
Yea Tiger thanks this info is great just what i wanted to do over the winter do this over the winter ... I must say that i ran across the Progression Ignition wireless Distributor and i very impressed with it Just the cost is very high at $500 us I live in Canada and that about $700 Cdn little to pricey the Pertonix III and the matching coil is about $300 all in
Old Nov 24, 2021 | 07:17 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
A properly setup and curved Corvette points distributor with a vacuum advance stop or adjustable can is as good as it gets for performance and running "smooth".....as long as all components are in good shape....I.E.-Plugs, wires, cap , rotor......
You will find zero improvement in the way the car runs by installing an electronic trigger assembly like a Pertronics. What you will find is that you can leave the key in the "run" position without burning points......and I have found that they start a bit quicker in cold weather......
If you want to do something with real benefit, something you can feel....E-Mail our member Lars and ask him for his distributor and timing papers. If you follow them to a tee and set point dwell proper.....it will run to its full potential and you will see a large performance increase.
Lars' E-Mail is V8fastcars@msn.com.....
Jebby
Old Nov 24, 2021 | 05:38 PM
ebbnflow's Avatar
ebbnflow
Breakerless SE about $170 US (?maybe $230 CDN?) I'd go with its simplicity, hi-standards and easy refit back to points. It doesn't need another coil either.
BTW, 1971 is first year of low compression smog era. Base 1971 L48 OE dist has poor curve. It Needs a recurve and probably all-over freshening; do that first.
Old Nov 25, 2021 | 09:46 AM
Falcon1959's Avatar
Falcon1959
thank you once again for the great advise , I will start with opening my distributor make an inspection of the all the parts check the rotor that's its not wobbling tight before decide to refurbish it or just get a whole new one
Old Nov 25, 2021 | 09:50 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
it will run no better than a new set of points or a correctly set up old points
Old Nov 26, 2021 | 12:37 AM
7T1vette's Avatar
7T1vette
The condition of the condenser is almost as important as the points. They age and get weak; spark 'miss' begins. Make sure you install a fresh condenser whenever you need to get into the distributor. I had the Pertronix in the car when I bought it. Ran great....until it didn't. When the electronic ignitions fail, you can't "limp" home; the ignition just quits. Then it's "flatbed" time, unless you carry a spare module and tools to make the swap out. Points is definitely more reliable.
Old Nov 26, 2021 | 10:44 AM
sunflower 1972's Avatar
sunflower 1972
Here's a good read from our C1 - C2 friends regarding Pertronix.
Done with pertronix!: https://www.corvetteforum.com/forums...pertronix.html
Old Nov 26, 2021 | 11:41 AM
Falcon1959's Avatar
Falcon1959
yes very interesting mine running very rough and just going to check some things out feedback on this site is great I'm learning a lot from you guys had the vette for about 10 years and she always ran good till now , nice vette by the way mine is a 71 sunflower
To distributor
Old Nov 26, 2021 | 12:22 PM
Nowhere Man
a new set of points is 20 bucks or so. Set them up with a dwell meter and your get anther 15-20k miles out of them A widget is well over 100 bucks.
Old Nov 26, 2021 | 02:46 PM
sunflower 1972
Thank you. IMHO, save your money and forget the Pertronix. It ain't going to be any better than a properly set up points distributor. And as others have stated, a points distributor will get you home if you have troubles. Jebby's advice is sound, follow it to the letter. You won't be disappointed in the results, I can guarantee it.
Old Nov 26, 2021 | 10:16 PM
kossuth's Avatar
kossuth
This is the biggest reason to convert TBH. This is the reason we converted all of our old gas tractors on the farm from points and condenser in the dizzy to a Petronix style breakless ignition. Points and condensors along with 6 volt batteries haven't been used in over 50+ years in cars/trucks. The aftermarket parts people have a huge quality control issue with modern stuff high volume stuff. The issues with the niche components are 1000x worse.
