Wheel arch measurement
Old Dec 29, 2021 | 12:34 AM
socal79's Avatar
socal79
Default Wheel arch measurement
Hello all, I recently installed Vansteel rear coilover conversion on my flared 1972. The car still sits very high(33"from ground to center of fender lip)and I am wondering if my wheel arches are way out of whack from the flaring. Does anyone have the measurement of the wheel arch length and height, from an unmolested vehicle?
Old Dec 29, 2021 | 12:47 AM
SEVNT6's Avatar
SEVNT6
My '76 is 28 1/4" from the ground to bottom of the lip...
Old Dec 29, 2021 | 12:59 AM
socal79's Avatar
socal79
I was looking for a measurment from A to B, and C to D. To compare and see if my flares are just too high or misshapen.
Old Dec 29, 2021 | 01:18 AM
Richard Daugird's Avatar
Richard Daugird
My '74 measurements are A-B=32" C-D=16". My rear wheel lip is 27". How high are you from the lower fender lip, near the "A" in the picture? I am at 9". What size tires are those? Mine are 255-60.
Old Dec 29, 2021 | 01:24 AM
Richard Daugird
CraigH's Avatar
CraigH
Ignore my comment….I saw the photo you posted with what you wanted…
If your arches are flared a measurement from a stock car wont be a good comparison.
Possibly ground to the top edge of the rear guard would be a better comparison as well ?
My measurement ground to lip is 26-3/4” and I have Vansteel coilovers (but with shorter shock bodies)
Old Dec 29, 2021 | 01:26 AM
SEVNT6's Avatar
SEVNT6
A to B looks like 32".....It's a little tough to measure with the wheel on.
The gap between the top of the tire & the lip looks high.
Mine's about 2 1/2"...
Richard Daugird
I have the Van Steel Coil over kit in my garage myself ready to install...
Old Dec 29, 2021 | 01:37 AM
socal79's Avatar
socal79
The photo i posted is off of Google, just for a diagram. My fender sits much higher than that.
Old Dec 29, 2021 | 01:58 AM
CraigH's Avatar
CraigH
Is that photo after you fitted the Vansteel Kit ?
And if yes how far have you driven it to settle it in ?
The flare does look to be sitting high on the guard but what wheel tyre did it run before?
Old Dec 29, 2021 | 02:17 AM
Richard Daugird
Holy Hell something is way wrong there!
Old Dec 29, 2021 | 02:47 AM
socal79's Avatar
socal79
I have not driven it, only rolled forwards and backwards. The tire is a 275/60/15. I have the coils adjusted pretty high up, so I could lower it close to 2 inches more.
Old Dec 29, 2021 | 02:51 AM
CraigH's Avatar
CraigH
it will settle a bit after a good drive or…..set the shocks to 0 compression and 0 rebound and bounce the rear heaps. It would help if the rear tyres on on a slip plate as they need to move out as it bounces.
275 is a tall tyre as well.
just be careful how far down you take the coilovers. Measure the gap to the bump stop.
Old Dec 30, 2021 | 04:47 PM
derekderek's Avatar
derekderek
measure from the frame bottom near the wheels to ground. that measurement is about 7-1/4 inch. yours may well be way above that, in which case it is overall suspension height making the issue worse.
Old Dec 31, 2021 | 12:37 AM
socal79's Avatar
socal79
The frame height just in front of the rear wheels is about 8" give or take .25"
Does anyone have the measurment from the lip of the fender to the peak in the body? Thumb to tip of ring finger.
Old Dec 31, 2021 | 01:15 AM
SEVNT6's Avatar
SEVNT6
10 inches when measured from above the center of the wheel.
Old Dec 31, 2021 | 06:32 PM
socal79's Avatar
socal79
mine measure 8" passenger side, 7.5" driver side
To Wheel arch measurement
Old Dec 31, 2021 | 06:33 PM
wwiiavfan's Avatar
wwiiavfan
I don’t have mine in front of me, but I thought all these measurements are in the AIM?
Old Jan 1, 2022 | 07:25 AM
derekderek's Avatar
derekderek
ok then your wheel opening is 2 inches taller at the top than stock. which means front to back is probably opened up a lot also. and both sides don't match. either really big rear tires, new fender openings, or live with it for the time being.
Old Jan 2, 2022 | 02:14 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I have the Eckler mud flap flares, the A-B measurement is set at app. 32" from Eckler, hard to measure with wheels on the car.
The C-D is 28 3/16 in front & 28 1/16 in the rear. I notice that you don't have any flare lip on the well edge, are those custom or home made ?
Just eyeballing the side of the car look at the door key hole and go straight back towards the rear of the car, that line is right at the upper most part of you flare lip, off hand i would say the flare are about 2" mounted to high.
