69 Rear Plenum Drain
- I have seen some comments with people that have rivets in theirs but mine had hex nut screws and j nuts - is that a early vs late thing or what, AIM lists rivets?
- Tube and metal flange (cover) go in from the outside - Am I reading the AIM incorrectly because it seems to show the tube on the inside for the coupe?
- Is there anything that I should be doing to clean up the carpet from the inside since there appears to be no cover that dresses it up - Alan 71 did an amazing job trimming the carpet but didn't know if I need to do anything the keep the loop from unraveling? BTW you always trim the bush to make the tree look taller - that was a funny add...
Mike
AIM Pic
Here is the body drain hole with the j nuts:
My drain tube with marks from the j nuts:
And Alan 71 with his wonderful detail, no trim:
My 72 was riveted. On a side note though, one side of the actual drain outlet from the trough the fiberglass wasn't cut open from the factory. Tube, clamp, everything was on but there was no opening.... I thought it was just clogged but nope.
M
Here is it reinstalled, need to clean up the hex heads a bit.
Noticed I need to clean up the rotors as I was sitting there taking a break, that will have to wait until the snow/salt is gone
