Another new guy
Old Feb 26, 2022 | 11:10 AM
  #41
Phantom 79's Avatar
Phantom 79
Rescue I have been on Ebay but really need someone that knows more about these engines than I do to help out - have a couple local guys looking for me. As for Facebook - I will NEVER EVER go on that platform - absolutely refuse to support the owner/developer of that forum
Old Feb 26, 2022 | 11:11 AM
  #42
Phantom 79's Avatar
Phantom 79
I think the sales guys were just repeating what the seller told them - he was the one that returned the $$ I demanded back
Old Feb 26, 2022 | 11:13 AM
  #43
Phantom 79's Avatar
Phantom 79
They did not advertise as "numbers matching"
Old Feb 26, 2022 | 12:46 PM
  #44
seacliffe301's Avatar
seacliffe301
I'm curious, how did you come to find that it was in reality a 454?
I'm actually surprised that your "inspector" missed this as well. Generally these guys are pretty good at verifying authenticity and the like. Obviously his oversight
costed you dollars, as well as aggravation. Perhaps some amount of refund should be expected from him as well.
Old Feb 26, 2022 | 01:41 PM
  #45
derekderek's Avatar
derekderek
you want as close to orig as possible or a 427 to update to efi? check the parts you now have. pull valve covers and see if they are correct era 427 heads-possibly orig to the car-or giant chambered tiny port 454 peanut heads. intake may well be original also. pretty sure the 91 had very few 4 barrel intake options. i think best way to go is find the 427 block you want. if you put a 3.76 stroke crank in that engine it is is a de-stroked 454. not a 427! and the added upside is you are driving it while upgrading it.
Old Feb 26, 2022 | 02:37 PM
  #46
Phantom 79's Avatar
Phantom 79
Found out it wasn't a 454 thru a friend that stopped by to see it - once he saw and heard it he suspected it wasn't a 427 _turns out he and his brother were chevy motor heads from the late 60s early 70s. Showed me where casting # was and later that night his brother called to say that it might not be a 427 - guess they didn't want to pop my balloon. So I checked the #s myself and found it was 454. This was confirmed by my shop as they pulled the valve cover and confirmed it was peanut port 454 heads. As far as going after the inspector he was one of several people lined up for court action - but once I received the $$ I was asking for I decided I didn't want the aggravation of pursuing legal action
Old Feb 26, 2022 | 02:48 PM
  #47
Phantom 79's Avatar
Phantom 79
Its more about a traditional look than trying to be close to original - suspect there are several replacement parts in the car. As for efi - its as I mentioned earlier - it will just run better with all the altitude changes here in Colorado
Old Feb 26, 2022 | 03:09 PM
  #48
derekderek's Avatar
derekderek
then you need to decide on heads. date and casting number correct iron GM or aluminum aftermarket heads. check intake casting number. you need to see if it is a correct vette intake or the very low-rise iron 4 bbl intake sometimes found on 91 truck engines. and you likewise need to decide what intake as it is part of the efi system anyway. what is the number stamped on the pad in front of the right head? is there even a number there? apparently the 9286 is a somewhat special MK 4 block. maybe putting a crank and pistons and a set of heads in that block should be considered. hell, everything needs to be considered.
Old Feb 26, 2022 | 06:03 PM
  #49
Phantom 79's Avatar
Phantom 79
Previous owner put a new Edelbrock Performer RPM intake manifold on it with a new Holley 750. There is no number on the front pad - flat and smooth You mentioned the 9286 is a special block - can you tell me what that is? I think at this point I'm going to hold off on the engine rebuild/swap til next fall and just drive it with the new efi on it - that will give me time to do more research and think over the comments from the folks on this forum - and yes everything needs to be considered!
Old Feb 26, 2022 | 06:19 PM
  #50
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I go on there only for the marketplace. I dont do anything that would promote any kind of income for him. I just like a neighborhood sap meet type of deal. Craigslist has fallen off sharply. I sometimes find a deal on there. You could have someone else get you the information about the seller and contact him by email.
Old Feb 26, 2022 | 07:37 PM
  #51
derekderek's Avatar
derekderek
performer is a good intake. some efi like a single plane better. depends on which efi. there are people who put 8 injectors into a single plane intake for more direct port injection. take your time. do research. get a 10 buck ebay or jeff bezos borescope. and see if dished or flat or domed pistons. see if steel crank while doing oil change and rod bolt size. it will take more doing to get an idea what you have for a cam. you can measure lift at the valve. under .500 it is most likely truck smog or low perf marine cam. and if that bottom end is worth keeping, those peanut heads gotta go. you will rarely go above 5000 where they run out of breath, but it is the thought that counts!
Old Feb 27, 2022 | 09:17 AM
  #52
seacliffe301
How fortunate for you that your friend came along when he did (impressed that he "heard" the difference). It's unfortunate that this type of thing can happen considering the cost & investment at stake. Clearly you did your due diligence, too bad that the car dealer didn't do theirs. I looked at their current inventory. Given the high cost of the cars they sell, you would expect them to be above reproach in this regard. No doubt that they are regretting whatever oversight that led to this. As for the inspector, so much for his reputation and credibility. As buyers of cars like this, we rely on their expertise to insure we're making informed decisions. This oversight is inexcusable.
You mentioned potential court action. I applaud your course of action. It's too bad it came to this, I'm sure that this is not what you had in mind when setting out to purchase an old Corvette. The plus side is you've got a beautiful car to enjoy. Hopefully the dollars retrieved are enough to offset the cost of correction as well as the aggravation factor.
Old Feb 27, 2022 | 09:26 AM
  #53
Rescue Rogers
my 396 didnt like the sniper efi on a dual plane. Just kept flooding the motor with big droplets. it wouldt atomize like it should and did on my 327 with the low profile single plane. If you see your AFR mixture all over the place and it just wont tune the way it should then consider a single plane as a cure, but it has to be low profile to fit under you hood even though its a L88 hood.
Old Feb 27, 2022 | 08:24 PM
  #54
Phantom 79's Avatar
Phantom 79
The whole buying experience was certainly not what anyone would want. And I do thank my friends for pointing out that it was not a 427. Too bad the inspector or sales guys didn't catch it - not very professional - and bad on me for not asking the right questions. But thats in the past and now I'll move forward and try to decide the best way to upgrade the engine - just not right for a non high performance engine to be powering a corvette. And all the money refunded has gone back into the car - as I tell my friends its costing me money to get a corvette education - kinda like college. Thanks for your comments - much appreciated
  #55
Phantom 79's Avatar
Phantom 79
Nice to know - Thanks
Old Feb 27, 2022 | 09:07 PM
  #56
seacliffe301
Ahh, but look at the quality education you'll have. You'll be an expert
