QuickJack Trouble ?
Old Mar 6, 2022 | 02:43 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
Default QuickJack Trouble ?
I know a lot of you have QuickJacks. I've used mine only twice since I bought it and it worked great. I go to use it on my C3 this morning and one side lifts but the other doesn't. I switched hydraulic lines and it follows the line so it is a problem with the pump. The fluid is topped off and everything looks okay.
I called the company but they are closed today. I really wanted to get some work done on the car so trying here to see if anyone has any ideas. I don't want to start taking the pump apart and void the warranty.
Old Mar 6, 2022 | 03:20 PM
sunflower 1972's Avatar
sunflower 1972
Maybe something here:https://help.quickjack.com/support/s...rs/14000121617
Old Mar 6, 2022 | 03:22 PM
How Are You's Avatar
How Are You
https://help.quickjack.com/support/s...e-pump-Priming the pump pushes hydraulic fluid into the system. On rare occasions, there may not be enough hydraulic fluid in the system for the pump to produce force. Priming the pump usually resolves this issue.
Note: If your power unit does not have a relief valve, you cannot prime it.
To prime the pump:
  1. On the power unit, remove the relief valve, then place a rag over the cavity and hold it there.
  2. Press Up on the pendant control for a few seconds (until you feel pressure on the rag).
  3. Reinstall the relief valve.
The pump should now have enough hydraulic fluid to operate normally.
Old Mar 6, 2022 | 07:55 PM
ChiliPepperGarage
Originally Posted by sunflower 1972
I looked there already and didn't find any answers. thanks.
Old Mar 6, 2022 | 07:57 PM
ChiliPepperGarage
To prime the pump:
Not sure if there is a relief valve or not. There is a plug of some sort on the main body but not sure if that is it. I guess I just have to wait until tommorow and call them. Thanks.
To QuickJack Trouble ?
