Distributor engine damage
Old Apr 16, 2022 | 04:23 PM
nitan2k's Avatar
nitan2k
Default Distributor engine damage
Hello, 82 owner here. I was reassembling my intake manifold, when my grandpa mentioned that the reason he’s scared of removing a distributor is because, if it is misaligned, it could lead to “blowout” which could break the block. Is this true? And how can I ensure proper distributor installation with my engine reassembled?
as a side note, I marked the position of my rotor against the firewall upon removal, but since it’s my first time I don’t trust my marks 100%, so I’m looking for some secondary confirmation of the distributor installation. I have a timing gun by the way
Old Apr 16, 2022 | 05:49 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
No worries about engine damage from distributor misalignment and valve/piston contact. The valve piston relationship is solely determined by the timing chain. A misaligned distributor will only cause the spark to happen at a non-optimal time in the stroke cycle. You could certainly get a backfire but nothing is going to catastrophically fail mechanically.
Get your alignment as close as you can from your pics; more than likely it will run fine but may be a tad rough. Once up to temp, adjust the distributor with a timing light. While you wait for the temp, make continual checks of antifreeze drips from hoses, listen for vacuum leaks, add coolant as needed, keep an eye on the temp gauge.
Old Apr 16, 2022 | 07:00 PM
nitan2k's Avatar
nitan2k
yea that’s kinda what I thought. I was thinking I could also check advance while starting the engine without spark plugs, since I have to remove the plugs anyway.
Old Apr 16, 2022 | 07:30 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Not clear on that last comment. I've been turning wrench's for a living for about 50 years. Still can't get an engine to start and run without spark plugs. Perhaps you could get a timing light on it while cranking the engine with the starter and maybe get an idea if base timing is close. But that's a waste of time. And will run down your battery and heat up your starter.
If you haven't turned the engine at all since you pulled the distributor, then your marks should be fine. If you have turned the engine. You need to start from scratch and get the number one cylinder on the compression stroke.
Old Apr 16, 2022 | 09:45 PM
barkingrats
Agree with 4-vettes that you would likely be spending a lot of time and energy for not much additional peace of mind. You could static time the engine with a test light but you'd essentially be replicating what your pictures show you and you'll still need to get it more accurately timed with a timing light. Trust your pics and start it up. Since it has no fuel up top, it may take a bit of cranking to prime it - maybe up to 30 seconds (not sure how your year's fuel system works).
Leave the distributor just snug enough to hold its position but not so tight that you can't rotate the housing by hand. If it doesn't fire or backfires, rotate the distributor about 1/8" counter-clockwise and try again. Make small movements when attempting to get it to fire.
Old Apr 17, 2022 | 08:22 AM
Mr D.'s Avatar
Mr D.
Over the last 50 years of playing with cars I have installed a distributor in just about every non-correct position you can think of at one point or another and never broke a block.
Old Apr 17, 2022 | 10:10 AM
lars's Avatar
lars
If you need info on how to correctly install a distributor in the correct position, just drop me an e-mail request for my "How to Install Your Distributor" tech paper, and specify if you need info for points or HEI distributor. Complete with photos and instructions.
Lars
V8FastCars@msn.com
To Distributor engine damage
