Brakes advice please
Old May 12, 2022 | 02:30 PM
  #61
kodpkd's Avatar
kodpkd
You have SS sleeves. It will take more work to get them smooth, but should work well.
Old May 12, 2022 | 04:58 PM
  #62
Last Triumph's Avatar
Last Triumph
I ended up balling up a load of '0000' wire wool around a bobbin, soaked in WD40, chucked up in my drill and gave them a thorough cycle, which has brought them up glass smooth with almost a reflective surface like a well worn engine block cylinder - more than good enough and the rebuild kit will be here by the weekend, so all should be well.
Old May 13, 2022 | 04:46 PM
  #63
Last Triumph
My rebuild kit arrived today so I finished off refining the finish on the bores and probably got carried away with the therapeutic nature of the process, but nonetheless, here are the results....
​​​​​​Name:  Qu3AEMH.jpg
​​​​​​Name:  hrMGm3m.jpg
Got everything reassembled and the system bled, ready for road test tomorrow if the weather is kind.
I shall report the outcome.
Old May 13, 2022 | 09:42 PM
  #64
kodpkd's Avatar
kodpkd
Good therapy.... WOW, really nice mirror finish.
Old May 14, 2022 | 12:16 PM
  #65
Last Triumph
Just to bring this thread to hopefully a close, got the calliper refitted, system bled, new pads both sides and took for a drive - it's like a different car.
Firm pedal, stops straight as a die and just feels so much more stable and planted under braking.
I'm really please, thanks everyone for your input, help and advice.
Old May 14, 2022 | 03:26 PM
  #66
Mark G's Avatar
Mark G
Glad you got it working!
When the car sits for periods, like over the winter, go out and press the pedal hard a couple times ...every 3 weeks or so. That'll keep the lip seals from 'sticking' to the sides of their bores (and last a lot longer).
Old May 14, 2022 | 09:15 PM
  #67
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I do not recall you saying if you checked your rotors for runout. They are "new" so that means they will have some runout, it's because of the old GM hubs.
Your left rotors appear to be original since they still have the factory rivits. The rotors on the right do not.
When the rotors pulsate the pistons, they pump air and/or water in behind the dust seals. It gets trapped there and corrodes everything. That was the "crud" you found.
Please check the rotors or your new brakes may not last long at all. Done right they are very reliable. But only when they have zero rotor wobble.
Old May 15, 2022 | 04:01 AM
  #68
Last Triumph
I checked the fronts as best as I could without removal and they looked fine, albeit maybe not perfect. The O ring design in the rebuilt calliper should help this factor I guess?
This is where my head is at this time round... this was a quick fix to get back on the road and identify the bad calliper and cause of my braking issues. Due to the cost of imported goods over here in the UK, it was about $175USD just for the pads and rebuild kit for one calliper, not a huge amount less than brand new Wilwood (per calliper) without the design issues.
If I'm faced with more brake rebuild or component replacement costs in the future, or have to start spending time and money replacing rotors with run out issues, just to continue to fight against the endless tide of bad calliper design, I'll bit the bullet and go Wilwoods all round as I feel piling lots of (UK import costs makes this more of a financially viable plan) money into the current system is a false economy - in my world anyway.
Hope that makes sense.
Old May 15, 2022 | 09:55 AM
  #69
kodpkd's Avatar
kodpkd
What pads did you decide on?
Old May 15, 2022 | 10:16 AM
  #70
Last Triumph
Just the semi-metallic generics that they had in stock at the same place I got the O-ring seal kit from.
I didn't give it much thought to be fair as I only baby the car.
As long as they work I'm good.
Old May 15, 2022 | 10:20 AM
  #71
kodpkd's Avatar
kodpkd
Good choice. They work well, when all you want to do is push the pedal and want the car to stop.
Old May 15, 2022 | 10:44 PM
  #72
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
It is not hard to check the runout on the rotors. Especially for an engineer. Just use a dial indicator.
Correcting it is not difficult either, just time consuming. You can buy rotor shims or make them out of any convenient shim metal stock you can find. .001" to .004" thickness should be good.
There is just something satisfying about making an old car run "perfect" LOL
Old May 16, 2022 | 02:32 AM
  #73
Last Triumph
I do have a dial indicator and will dig it out next time I have the wheels off.
What would you attach it to as the fixed reference point on the car, given they are not held in place firmly with the wheel removed?
Old May 16, 2022 | 02:41 AM
  #74
Bikespace's Avatar
Bikespace
Attach the base to the trailing arm (rear) or spindle (front), with the clamp or the magnet. The runout relative to the brake caliper is what is really important, so for extra credit, you could mount the base to the caliper bracket. I'd think you'd want to test the runout with the caliper removed anyway.
I'm assuming you don't have rivets anymore, so be sure to hold the rotors on with a few lug nuts.
Old May 16, 2022 | 02:46 AM
  #75
Last Triumph
Thanks, will give that a shot.
Old May 17, 2022 | 01:08 AM
  #76
Mark G's Avatar
Mark G
I have some really heavy cast iron press-plates for a press. On some vehicles, like 4x4 trucks or a car where the wheel is up on jackstands, I put some water in a 5 gal bucket (for weight), and put a press plate on the lid. And attach the magnetic base to the press-plate. The bucket is pretty solid (as long as the concrete isn't uneven) and the press plate fits nicely in the center of the lid. It's pretty solid. But you could do something similar with some steel you might have around the shop, even if it's just 1/4" thick. It's a no-cost idea to keep in mind when you can't attach to a spindle.
Make sure to get some oversized nuts that'll fit over your studs ...and bolt them down. You really don't need to torque the lug nuts and rotor to spec tightness, to test for run-out, ...just get them fairly tight, before you test it with the dial indicator.
Old May 17, 2022 | 02:57 AM
  #77
Last Triumph
Originally Posted by Mark G
I have some really heavy cast iron press-plates for a press. On some vehicles, like 4x4 trucks or a car where the wheel is up on jackstands, I put some water in a 5 gal bucket (for weight), and put a press plate on the lid. And attach the magnetic base to the press-plate. The bucket is pretty solid (as long as the concrete isn't uneven) and the press plate fits nicely in the center of the lid. It's pretty solid. It's a no-cost idea to keep in mind when you can't attach to a spindle.
Gotcha.
One of the many challenges we have being in the UK and of metric persuasions, is that regular lug nuts of American threads just aren't in a coffee pot on the shelf waiting to be sorted through to hold the rotor in place, nore a collection of American taps to create at will. I'll figure something out.
To Brakes advice please
Old May 17, 2022 | 09:53 AM
  #78
71 Green 454's Avatar
71 Green 454
Gotcha.
Just use a few washers, then install the lug nuts to hold the rotor in place.
Old May 17, 2022 | 12:32 PM
  #79
Last Triumph
Good call, or a short length of plumbing copper pipe.
Old May 17, 2022 | 09:00 PM
  #80
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
My right front bearing was wobbling over .010 all by itself because the adjusting nut was too loose. That may need to be checked for proper adjustment as well.
