AC Delete
Old May 15, 2022 | 10:10 PM
Stevewv's Avatar
Stevewv
3rd Gear
Default AC Delete
I just removed the compressor and hoses from my factory air 68, it didn't really work anyway. Heater hoses were already removed when I bought it. However I do want the heater for fall & early spring driving. Can I simply hook the heater hoses back up to have functioning heat? Or do I have to use some kind of AC delete kit? TIA
Old May 15, 2022 | 11:21 PM
thatcorvetteguy's Avatar
thatcorvetteguy
Yes buy AC heater hoses hook them up and you'll get heat, provided your heater core doesn't leak. You can PM me if you need more answers.
Old May 16, 2022 | 01:31 AM
Peterbuilt's Avatar
Peterbuilt
Default You will need molded hoses
Old May 16, 2022 | 06:56 AM
Stevewv's Avatar
Stevewv
3rd Gear
Thanks guys! Wasn't sure if the controls would work right or not.
Old May 16, 2022 | 09:05 AM
interpon's Avatar
interpon
if you go to the trouble of putting moulded preformed hoses on and may or may not find a leak... or may want no water in hot weather.. i would instal 2 shut off valves one on each hose just in case...so you can at least have the option
many threads on this
Old May 16, 2022 | 09:22 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Before you connect the two hoses to the block/water pump, flush the heater core with water.
Old May 16, 2022 | 10:58 AM
REELAV8R's Avatar
REELAV8R
Often times the heater core hoses are bypassed due to a leaking core. Be prepared for that possibility.
To AC Delete
