Rear gear
Old Jul 17, 2022 | 08:44 AM
Golferdad's Avatar
Golferdad
Default Rear gear
I’m doing some engine mods,I bought this vette in February a 1981 and it was stock,but I just recently found out that I have a 272 gear,although I only drove the car maybe 100 miles,and 60 of that from NC,where I bought it back to SC, so,how hard is it to remove the gear box,because I have the engine apartand of course can’t take it no where,so,plan on removing it and taking it to someone to put in my new ring and pinion gear set.like how high do I need to get it out,and any special tools to remove it. Thanks
Old Jul 17, 2022 | 08:57 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
theres no special tools required but you want to be careful taking the rear spring suspension bolts out while its attached to the trailing arm if it still has tension on it. just dont drop it on your head. Post pics as you go
Old Jul 17, 2022 | 09:03 AM
TX Driver's Avatar
TX Driver
I assume you are talking about the differential when you say gearbox? The differential is not difficult to remove, although I have the luxury of a car lift to make life easier. Removing the rear spring is the only thing that can be difficult and can also be dangerous if not done correctly. There are lots of YouTube videos on that process. Be prepared with extensions and sockets with universal joints to remove the axles and disconnect the driveshaft and U-Joints, take your time and plan how to go about pulling the differential.
Old Jul 17, 2022 | 09:36 AM
Golferdad's Avatar
Golferdad
Yea,sorry differienal,I know I’ve always heard hog head,but different axles,I think over the years have seen a lot of stuff with cars,but have never seen one pulled.
Old Jul 17, 2022 | 09:45 AM
Fly skids up!'s Avatar
Fly skids up!
Not a special tool but a 1/4 inch 12 point socket is need. Mark the camber eccentrics too.
Old Jul 17, 2022 | 02:27 PM
Rescue Rogers
Go to you tube and find some videos. It will give you an idea of what can cause issues. You dont have the sombreros that are a pain if they are sticky and you might miss a few things like the front bushing that seems to hide itself. I dont know how easy iot is to get to your top bolts for the batrwing. I would hose it all down with penetrating oil the noight before you start
Old Jul 17, 2022 | 02:53 PM
Fly skids up!
The Batwing bolts are easy.
Old Jul 17, 2022 | 03:36 PM
TX Driver's Avatar
TX Driver
It helps to have long extensions and and 1/4" universal joint 12 point sockets. Like these.
Amazon Amazon
I will second the importance of marking the camber eccentrics!!!
Old Jul 18, 2022 | 08:10 AM
hdeyong's Avatar
hdeyong
Just a quick side note. Unless you know they're new, replace the U-joints while you're at it.
Old Jul 18, 2022 | 08:56 AM
Golferdad's Avatar
Golferdad
Oh they are definitely not new,hadn’t looked back there real good yet,and still have the spare tire cover in place,and I’m pretty certain that when I take it off,it will be the original tire.but,yes will definitely replace the u joints.
Old Jul 18, 2022 | 03:55 PM
Richard Daugird's Avatar
Richard Daugird
What gear did you finally decide on?
Old Jul 18, 2022 | 03:57 PM
Golferdad's Avatar
Golferdad
Still haven’t decided yet,but leaning toward 355.
Old Jul 18, 2022 | 07:42 PM
Richard Daugird
Are you gonna go with an overdrive transmission? If you do you might as well go big. 373 or 4/11 baby!
Old Jul 19, 2022 | 11:44 AM
Z0Tex's Avatar
Z0Tex
Subscribing to this thread. Thinking of doing a diff swap on my '80 (3.08 to 3.36 or 3.55).
Old Jul 19, 2022 | 12:15 PM
Fly skids up!
I'm in the minority here. I have a 700-r4 and went from a 2.87 to 3.07 rear with the intent of regearing my original rear with 3.31 gears. After having the 3.07 for a while, I have no intention of the 3.31 regear.
To Rear gear
