Transmission fluid
Old Jul 27, 2022 | 06:18 PM
mikem83's Avatar
mikem83
Default Transmission fluid
I need transmission fluid for my 76-3 speed automatic. It says on the stick use Dexion. I purchased ValvolineDEX/MERC ATF Conventional Automatic Transmission Fluid but I am confused by the DEX/MERC what is the MERC and is it the correct fluid.
Old Jul 27, 2022 | 08:48 PM
Motorvation's Avatar
Motorvation
Mercon is Ford mix. Dex/ merc is combo mix. It’ll work. I suggest buying Lubegard red to add to your fluid top off. Pricey but good stuff. You’ve got a TH350, the fluid just needs to be red and slippery. If you’re fighting leak problems, put Lucas trans add, slippery snake oil, MEK laden fix some seals in it.
Steve O.
Old Jul 28, 2022 | 05:06 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
To Transmission fluid
