Starter
Old Aug 30, 2022 | 09:18 PM
bobby70's Avatar
bobby70
Default Starter
Hi every ones so I wanted to go for a ride with my 70 money Pitt every thing new but when I turned the key all I heard was the 6 month old starter just spinning no contact with the motor so I think I have to buy a new one,AGAIN thanks again bob
Old Aug 30, 2022 | 11:18 PM
beachmusic's Avatar
beachmusic
If it [starter] spins that well [no excess amperage draw] just replace the bendix. Used to be a common issue. If starter motor is good why chance another china rebuild?
Old Aug 30, 2022 | 11:41 PM
bobby70's Avatar
bobby70
I purchased it at Napa will they have the bendix and how hard is it to fix thanks
Old Aug 31, 2022 | 04:06 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yes NAPA should have a bendix. Fairly easy to replace.
Old Aug 31, 2022 | 08:26 AM
stingr69's Avatar
stingr69
The bendix is pretty cheap and easy to replace. The solenoid has 2 screws holding it on. The starter has 2 thru bolts holding it together. The bendix has a snap ring holding it on the end of the shaft.
The brushes are not that bad but you need them in place first at reassembly. Use 2 pairs of pliers to
reassemble the shaft snap ring cover.
Maybe 15 minutes once you have it on the bench.
Old Aug 31, 2022 | 09:49 AM
HeadsU.P.'s Avatar
HeadsU.P.
While the bendix is off, good time to swap it out.
Purchasing a more expensive unit with a Ceramic (brown) end cap is a good investment. Handles heat much better.
But first: Photograph and label the small wires to the solenoid (with masking tape & a Sharpie) their location before removal.
To Starter
