The Dreaded Driver's Side Dash Installation
I think I will fabricate a brace that actually fits without putting the reset cable in a bind.
Hopefully tomorrow I will be reinstalling the dash.
Thanks to the members who convinced rookie-me to drop the column AND ADD 1 FOOT OF color-coded wire to each gauge & light wire.
I was able to ziptie the main dash harness tightly in place and plug the modified wiring into the new connectors. Now I can literally pull out the driver panel without fighting the harness or without disconnecting the wiring...it also makes the speedo/tach cables much eaier to disconnect-reconnect.
The same thing with the center gauge cluster....it can be repaired and tested because of the long modified wiring.
Thanks again Members.
Speaking of custom bracing for convertibles, the pass side brace doesn't fit with Vintage Air, as they designed their system for a coupe. So made a 1/4" thick x 1" wide bar brace to fit around the AC/heater box.
According to GUSTO14, it does go up and around the brace on install to prevent the sharp bend and potential damage of the cable at the speedo.
(since my car is/was a basketcase originality is not a priority)
This photo shows the under dash wiring. Here all the wiring is laying on the ground. At the bottom is the main passenger side firewall harness and the dash pads and their wiring. You can see that the wires from the firewall harness, going to the tach/speedo lightbulbs, has been cut. I've added wiring to increase their length and added connectors that will be used to join the tach/speedo lightbulbs to the main harness. After installing the firewall harness and the dash pads, the interconnecting wires, and their connectors, are just dangling down, easy and convenient to reach after the interior parts have all been installed. Just "stand" on your knees outside the car, reach in, snap the connectors together, and voila...the wiring connections are all made.
To avoid a Bubba look, I used OEM connectors, Packard Electric. It's a little pricey. You have to buy packages of male/female connectors, pins...different pins for different gauges, and connector pin seals...little rubber plugs that make the connectors water resistant, and all the different colored wires and gauges. You also have to buy pin inserting tools, pin removal tools. This makes connecting the harness wiring to the console speedo/tach and also all the center console gauges just real easy.
I am not getting any pictures of the way you increased your dash wiring.
Can you send them to me?
