71 LS5 Engine rebuild
At the end of the summer it was using too much oil and when I put the right foot down I'd drop a good cloud of smoke.
I have had a hard time finding a good mechanic and only want to do this once and do it right. Since its above my Technical limit I need to hire it out.
I begrudgingly joined facebook (I don't social media) and did find a Minnesota Corvette group with some very nice folks. My current engine was just rebuilt in 2018 so mostly high end newer parts ( I have the build sheets).
I inquired about a rebuild and have had a couple offer their services. One was laughed at by another member and the other seems quite knowledgeable, unfortunately I am not. That being said, was hoping for some guidance through the project.
What can I expect for a ballpark cost? $3K -$5K ?
What questions should I be asking?
What do I need to brace myself for?
Engine information - LS5 - 454 BB. Some of the parts already installed are Crower competition forged cam and Manley forged rods. I am a little leery of the Carburetor (SMI Q-Jet) after speaking with the original Mechanic who did the last rebuild (said had major balancing issues with the bleeder)
The Engine
Have you talked with the previous builder about the oil consumption?
It isn't smoking badly, only when I really jump on the accelerator. The previous owner (former member here) did not have this issue.
The vehicle sat for a period of months and I accepted delivery in December. I was quite excited to receive it so jumped right in and and put it on the highway (20° F out) and proceeded to hammer the the throttle.
Tach went nuts, snapped the needle in half and that is when I believe I damaged it.
I did put a little over 5,000 miles on it this summer. I use over a quart per full fuel tank. No noticeable smoke when driving.
I have struggled to find a good mechanic locally.
Do you think you "over revved" it and that is the when the issue started? If you don't hear any new ticking, clicking, rapping, or knocking, especially under load, then you likely didn't damage any of the rotating components or their bearings. Pull the plugs and see how they look. Wet & oily is likely indicative of worn valve guides or damaged/missing seals. If you post pics of them, you'll get some feedback on where to go next.
If the heads are cast and you are concerned with numbers matching have them rebuult at a machine shop...not a grage or facebook buddies house.
If its not a collector year or there isnt a numbers concern go with a 265 275cc intake volume small chamber head. 115 to 119cc.
Good heads take a while to get currently expect to pay $2300 for the heads and $200 for good gaskets...dont buy cheap chinese heads, you may be able to find a good shim gasket for less to keep the qwench near stock.
You get what you pay for with the name Brands....
If that is the case, this issue will show up on the plugs (and out the exhaust).
A leak at the bottom edge of the Intake Gasket is somewhat common. It does not show up using the propane bottle leak test at the top of the gasket.
However, this type of leak issue may show up on a vacuum gauge as a jittery needle.
This is why it is so important to apply a good sealant on the whole gasket, both sides and not just around the ports.
It could be just one cylinder, it could be all eight burning oil from the lifter valley.
I would say your first step in diagnosing is to hook up a vac gauge.
Then pull and start reading plugs making note of which cyl is doing what.
I suggest you have someone remove the engine and then take it to a reputable engine builder. Most engine builders do not touch the actual car........
Skip trying to find a "mechanic" to do all........this is a potential rabbit hole of peril and money.......
If it is smoking under hard acceleration then the rings have lost seal.....for whatever reason......a quart every tank will show up on a leakdown tester.
I assume you mean this has a Forged Crower crank (not cam) and Manley rods......both are very high dollar pieces....and the pistons should be equally high dollar.......it may have been honed improper or someone F'd up and put a light tension oil ring in it......
A good engine builder will be able to diagnose the problem and not charge you for a complete rebuild.........it may just need a nice "ten pass" diamond hone and a good set of Total Seal rings......
Jebby
Jebby
Jebby
Jebby
Sorry yes, forged crank. Unfortunately the Mechanic that was referred to me last year is the one who told me I needed the rebuild, I just don't trust him to do it.
I'll ping the FB group and see if I can find a local engine builder as you suggest.
Here is part of the build sheet
I drive cars but don't speak the engine language about pistons being rebored and all that engine stuff
Remove the intake manifold and see if oil is all over the intake runners. That's what was causing mine to smoke because the gasket was not installed correctly.
Last would be the intake valve seals. Were the heads rebuild?
