Getting warm
Old Mar 19, 2023 | 11:54 PM
bobby70's Avatar
bobby70
Default Getting warm
Hi guys I need a new ac compressor for my 70 small block I seen alot of info on sandon compressor or the best one you like if you can send me the Webbsite that would be great thanks bob
Old Mar 20, 2023 | 05:05 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I believe your thinking of a Sanden compressor. You will need custom mounting brackets and custom hoses. Well worth it.
Old Mar 20, 2023 | 02:38 PM
7T1vette's Avatar
7T1vette
Classic Auto Air has reasonably priced complete conversion kits for your Corvette. It will convert your system to R-134a refrigerant which is much more available and much less expensive than R-12. You will need to have your VIR recalibrated for 134a OR replace it with a HI/LO system pressure safety switch tube (which I highly recommend). The Sanden A/C compressor is much smaller and lighter and MUCH more efficient than the old GM unit. If you need to replace the compressor and you don't need the car to be completely "original", this is the way to go.
P.S. You will need to purge ALL of the old lubricating oil out of the A/C system prior to refilling with correct oil and R-134a. You can purchase 'flushing' products from your local auto parts store. It's a bit messy, but it MUST be done, as the old oil and the new stuff you put in for the Sanden are incompatible with each other.
To Getting warm
