Buzzer won't stop until car is running
Old Apr 11, 2023 | 08:20 PM
slopoke17's Avatar
slopoke17
Default Buzzer won't stop until car is running
I have a 77 and over the winter I disconnect the battery. Now, when I connect the power the buzzer goes on with no key in the ignition. It stays on until I turn the key and start the car. Any suggestions on what's causing this? Thanks for any help.
Old Apr 11, 2023 | 10:13 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
3 things make it go off. Key left in ignition. Lights left on. And seatbelt warning.
if the lights are off, the key is out of the ignition, you will need to track down which of these 3 are setting off the buzzer.
Old Apr 12, 2023 | 12:17 AM
slopoke17's Avatar
slopoke17
That's the odd thing about it, key is not in ignition, lights are off and it stops after I start the car up even without seatbelts engaged. As soon as I connect the battery shut off it starts buzzing.
Old Apr 12, 2023 | 03:44 AM
4-vettes's Avatar
4-vettes
Step 1.
Buy this book!
Step 2.
I took photos from this book that you can blow up and hopefully read. This should guide you.
Now this should get you started. Then BUY THIS BOOK! as you can see it's really helpful.
Old Apr 12, 2023 | 05:54 AM
corvgreg's Avatar
corvgreg
Emerging Vendor
A door is open when you reconnect the power, right? If you shut the door does the buzzer stop?
Is the door shut when you start the car and the buzzer goes off? If it is open the door while it is running. Does the buzzer come back on? It may be a broken key in buzzer switch inside the column.
__________________
Greg
Old Apr 12, 2023 | 12:43 PM
sunflower 1972's Avatar
sunflower 1972
The key buzzer on my 72 occasionally acts up on mine. I just jiggle the ignition lock escutcheon until it stops. The problem is the lock cylinder buzzer actuator. See post #3 in this thread: https://www.corvetteforum.com/forums...zer-alarm.html
Old Apr 12, 2023 | 01:35 PM
sunflower 1972
Here's the buzzer
Old Apr 12, 2023 | 04:45 PM
4-vettes's Avatar
4-vettes
That's the switch inside the column. The buzzer is down by the fuse box.
Old Apr 12, 2023 | 06:29 PM
sunflower 1972
You're right, my bad. What I screenshoted is the buzzer switch. Buuut, if you want to Bubba the repair, just pull the buzzer.
Old Apr 12, 2023 | 11:09 PM
slopoke17's Avatar
slopoke17
Step 1.
Buy this book!
Step 2.
Thank you, appreciate getting this for me. I'll check for that book too!
Old Apr 13, 2023 | 08:16 AM
4-vettes's Avatar
4-vettes
Old Apr 13, 2023 | 08:53 AM
slopoke17's Avatar
slopoke17
Found the trouble shooting manual on ebay for $14!
Old Apr 14, 2023 | 02:00 AM
Dino_'72's Avatar
Dino_'72
I was also thinking the same. Slowpoke does door open or closed affect the buzzer?
Old Apr 14, 2023 | 09:12 AM
slopoke17's Avatar
slopoke17
I checked the 3 items listed above. Buzzed with doors open or closed, seatbelts OK. Checked for light on, I found the buzzer stops after I turn the headlight dimmer. I thought maybe the dome light was on so I started turning the **** and it stopped buzzing. I have to turn it all the way off to stop it. I'm thinking my gauges will need to be turned on after I start the car every time I drive at night, no big deal as I never go out at night with it. Sounds like the rheostat is bad?
Old Apr 14, 2023 | 01:08 PM
bmotojoe's Avatar
bmotojoe
Once the **** is turned all the way CCW there is a stop (detente), turn it past the detente and the courtesy lights will come on.
Doing so changes the circuit path bypassing rheostat, the diagram on page 18 shows that.
You are no longer sending power to the headlight warning portion of the buzzer.
If you want to disable the headlight warning only, unplug the Green connector (with Grey wire not black as diagram shows) from the fuse panel.
You will see the socket labeled on the drawing LPS.
Now, it could be that the headlight switch just needs to be pull/pushed back in many times,
Do this with the battery disconnected.
Old Apr 14, 2023 | 04:44 PM
4-vettes's Avatar
4-vettes
Score! You will never regret purchasing this!
To Buzzer won't stop until car is running
