Spring Cup installation tool
Old Jun 14, 2023 | 11:21 AM
69XR7's Avatar
69XR7
Default Spring Cup installation tool
Does anyone have the tool to install/flare the cups for the springs and trailing arm that they would be willing to loan out.
I hate to spend $50 to buy a tool that i'm only going to use twice.
Old Jun 14, 2023 | 03:35 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Rear Spring Bushing Retaining Cup Install - CorvetteForum - Chevrolet Corvette Forum Discussion
I have an old obsolete socket with a bevel that I use.
Be happy to loan you the socket and you can put together the bolts, washers, and other socket to complete the setup.
See post 11 in link.
Or, found a similar beveled socket on ebay, $12
https://www.ebay.com/itm/143877928505
Old Jun 14, 2023 | 04:08 PM
Tuna Joe's Avatar
Tuna Joe
I used a ball peen hammer and large fender washers (these go inside the cups) to support the cups while hitting the ball peen hammer with the sledge.
The ball portion of the hammer fits the part to be flared over. I used a 2 pound sledge to hit the ball peen hammer which flares the cup.
I did have to bring the new cup to Lowes to size the correct sized hammer before I started.
Old Jun 14, 2023 | 06:55 PM
69XR7's Avatar
69XR7
a $12 socket i can do - I’ll just buy that. I have plenty of bolts and washers to do the job
Old Jun 14, 2023 | 07:59 PM
GTR1999's Avatar
GTR1999
I have the tool and have also done 100's with nothing more than a ball peen hammer. Different weight hammers have different ball ends, so I use a couple. To make it easier to do I have a steel rod I clamp in a vise. I put the arm over the rod and a round steel disc to sit in the cup. That holds the cup in the arm and I can peen the end over. The tool will roll over the cup stem smoother.
Old Jun 14, 2023 | 08:23 PM
69XR7's Avatar
69XR7
I’ve got a couple ball peen hammers and I’m getting the socket. So between those I should be able to do an acceptable job on the two trailing arms.
To Spring Cup installation tool
