Pulling the Plug.
Old Aug 1, 2023 | 06:33 AM
doning's Avatar
doning
Default Pulling the Plug.
Here is an embarrassing question, how the heck does the proportioning valve electrical connector unplug? It spins and moves around but I cannot pop it off! Is there a tab I have to squeeze? Thanks!
Old Aug 1, 2023 | 10:34 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It's just a straight pin that the connector plugs onto and should just pull straight off, 90° to the body of the block. Maybe a pair of slotted screwdrivers working/prying the electrical boot off...
Old Aug 1, 2023 | 11:36 AM
doning's Avatar
doning
Okay, thanks 67:72!
Old Aug 1, 2023 | 01:19 PM
doning's Avatar
doning
Who makes a good proportioning valve at a decent price?
Old Aug 1, 2023 | 01:32 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Go to my thread...click on this link> https://www.corvetteforum.com/forums...post1586196251
my prop. valve (directional valve) on my '68 was frozen internally. I diassembled cleaned reassembled it.
It's been working great for 9 years.
It may/may not be similar to your valve.
Old Aug 1, 2023 | 01:45 PM
doorgunner's Avatar
doorgunner
Once you remove the electric connector from the Prop. valve...does the dash light stillturn on or flicker when you apply the brakes in park/drive/reverse?
As a member said in your other thread...it could be a valve problem or could be a wiring/swtch out of adjustment problem.
ASK THE MODERATOR TO COMBINE BOTH THREADS SO MEMBERS ARE "ON THE SAME PAGE".
Old Aug 1, 2023 | 02:28 PM
doning's Avatar
doning
That's what I want to try if I can get the connector off.
Old Aug 1, 2023 | 03:23 PM
Duke94's Avatar
Duke94
Go to this site.
https://www.musclecarresearch.com/gm-parts. He has a good selection of parts for rebuild.
Old Aug 1, 2023 | 07:22 PM
1971CorvetteII's Avatar
1971CorvetteII
If I'm not mistaken you might have to squeeze it, doesn't it have 2 ears on it ?
Old Aug 1, 2023 | 08:38 PM
Duke94's Avatar
Duke94
Correct, it has a nylon piece that has 2 fingers that latch to the flange on the switch. If you have the retainer off and the rest won't pull out, chances are that the terminal is corroded to the post on the switch.
To Pulling the Plug.
