Ecm mounting 82 C3
Old Sep 2, 2023 | 11:55 AM
Dwonch's Avatar
Dwonch
Cruising
Default Ecm mounting 82 C3
Can someone provide a picture of how the ECM mounts in the battery box. Mine was just laying loose when I purchased it.
Thank you
Old Sep 2, 2023 | 01:07 PM
Prysmian46's Avatar
Prysmian46
Default ecm location
Thank you
A pic probably will not help due to it location. Remove the battery and you will see the bracket under the storage panel cover. The ecm mounts to the bracket with the studs and nuts provided on the ecm. Then reinstall the battery. Hope this helps.
Old Sep 2, 2023 | 10:03 PM
Dwonch's Avatar
Dwonch
Cruising
Default Re
thank you I will check it out
To Ecm mounting 82 C3
