Brake light switch
Old Sep 9, 2023 | 10:03 AM
PKJOHN's Avatar
PKJOHN
Default Brake light switch
I’m on my 4th brake light switch in 3 years. My mechanic said he replaced it with the same one that was replaced before from NAPA higher priced one. When there replaced they work for awhile.There made in China! Is there anyone that knows a company that makes one made in America? He checked for short and ground, everything’s good. I do not like driving with no brake lights!
Thank you
Old Sep 9, 2023 | 12:27 PM
MelWff's Avatar
MelWff
Look at this one
https://www.lectriclimited.com/catal.../category/751/
Old Sep 10, 2023 | 08:15 PM
PKJOHN's Avatar
PKJOHN
Thank you, I’m going to check it out hopefully it’s made in the USA.
Old Sep 10, 2023 | 08:20 PM
PKJOHN's Avatar
PKJOHN
I’m going to check this out, hopefully it’s made in the USA.
Thank you
Old Sep 11, 2023 | 10:14 AM
redwingvette's Avatar
redwingvette
I changed out two of them years ago. The last one I put in I opened it up and gave it a shot of white lithium grease before I installed it. It’s been there about 10 years now without any issues
Old Sep 13, 2023 | 02:28 PM
C3_DH's Avatar
C3_DH
@redwingvette , at the suggestion of a local Corvette shop owner, I did the same. Mine has been on for about 2 years, hopefully mine will last as long as yours!
Old Sep 14, 2023 | 06:47 AM
stevedinino's Avatar
stevedinino
Just curious, how is it failing? Contacts burned? Plunger bad? Connector issues?
Mine was replaced 5 years ago with AC Delco part most likely from down in Mexico. Still working. Fingers crossed.
Old Sep 14, 2023 | 07:18 PM
loup68's Avatar
loup68
Army
When I first saw this, I thought you meant the horrible, bastard old Chevy truck brake light switch that GM had the nerve to put in our 68's to save a couple of pennies! I replaced the evil thing with a 69-up switch setup with GM counter parts and a switch that I got out of a junk yard in 1975. It lasted until a couple of years ago. Lou.
To Brake light switch
