Radiator Replacement Advice
pics? shroud in place? seals? spoiler?
i do not think you can go wrong with aluminum radiator compared to OEM if same size or bigger, try that prior to adding fans. how clean is the radiator looking at openings?
here is a thread sticky
https://www.corvetteforum.com/forums...ed-topics.html
i like anything not china.. dewitts is a sponsor here.
The DeWitts budget radiators seem like a good deal. Corvette Ben recently did a video on them. You can get them from Zip for ~500-. Made in USA.
https://www.zip-corvette.com/73-76-3...-radiator.html
I have found that the Champion radiators are a good quality product. You just have to find one of the right length/width with the number of rows you need (A/C?; perf engine?) and the tank and connector configurations you require.
Have you pressure tested the cooling system, both cold, AND warm? (Warm it up with the cap off the radiator or expansion tank, THEN attach the pressure tester)
A cooling system that is not holding pressure will CONSISTENTLY run 15-20 degrees hotter than one that is. All it takes is one loose hose clamp! Get underneath, check
the clamps on the hoses going to the heater core!
https://www.reddit.com/user/wadenels...dy_diagnosing/
Key takeaway: Don't lie to yourself. If the needle on that gauge drops AT ALL in 15-20 minutes, you're losing pressure!
One of the most important (and neglected) is all the foam seals around the radiator, condenser, etc. preventing air from going over or around or under instead of through the radiator. Seal kits are cheap.
Contrary to what some *unnamed persons* claim, there are no inherent design flaws in the C3 Corvette cooling system. If every piece of the SYSTEM is doing its job, as designed, it works just fine without massive electric fans, etc. It has more than sufficient BTU capacity to get rid of the heat generated, big block, small block, meaner cam, etc.
Jebby tells everyone to check for overly retarded timing but TBH I've personally never diagnosed a car that was overheating where that was the sole cause, at most, a contributor.
then I moved overseas to Queensland. Much, much hotter climate. Put in a Aluminium rad as my car wasn't happy. All seals in place. Made up new seals and block off plates to cover what the factory missed. Car was fairly happy. Not really in 115 degree heat. Then I bumped up performance even more. Now everything needed to be addressed. Perfect timing was likely the biggest. Extra long front spoiler helped a fair bit as well. Still.
110 degrees with air-conditioning running at a traffic light I was chewing my finger nails watching the temp gauge.
HUGE 4 row Aluminium radiator next. C5 electric fans.
Car is always happy. Never over 195 on the hottest days with air-conditioning running.
everything is important. A huge radiator does make a difference!
