nicely done restamp
Old Sep 14, 2023 | 07:20 PM
derekderek's Avatar
derekderek
Default nicely done restamp
Old Sep 14, 2023 | 08:42 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
that is a real stamp from the Balitmore assembly plant for an A body with a 396/360
Old Sep 14, 2023 | 11:01 PM
Greg's Avatar
Greg
Just another Corvette guy
Looks like the whole gang holder idea went right out the window there.
....and if you're going to re-stamp (which I have no problem with) deck it far enough to remove all of the old numbers.
Old Sep 15, 2023 | 07:32 AM
Nowhere Man
that is 100% how they looked from Baltimore.
Old Sep 15, 2023 | 07:58 AM
gbvette62's Avatar
gbvette62
Before VIN stamping blocks became Federal law in 1968, only the St Louis Corvette plant stamped VIN's on every block. Passenger car plants only stamped VIN's on engines higher than 300 horse power and apparently rarely if ever, used a gang holder. The VIN stamp on that block is very typical of the stamps found on blocks from passenger car plants. It wasn't even standardized as to where the VIN was stamped, with some plants stamping it in other places, like near the oil filter.
At St Louis it was quicker to use the gang holder and change one or two stamps for each block. At passenger car plant like Norwood, Baltimore, Wilmington, etc, they may have only had to stamp the 10th, 50th or 75th block that came by, so it was probably easier and simpler for the person stamping the VIN's to just stamp each digit individually, then to load and unload a gang holder over and over.
I don't have any direct proof of this, it's just an assumption based on what I've observed over the years.
Old Sep 15, 2023 | 09:30 AM
Nowhere Man
Glen I would say your right on no gang holders for passenger car plants prior to 1968. and to put it into perspective on how many engines got stamped for 1966 Chevelles there was a total of 447,364Chevelles built. out of those only SS 396 engines was advertised over 300Hp so those where the only ones stamped only 72,272 where made. But Balitmore assembly plant only made 88,331 of those 447,364 cars or 19.75% of those cars. how many 396 cars made at Balitmore is not known. but as you can figure out, they didn't have to stamp a lot of engines. so being slopy and out of line is normal. and being an early EF block it should be a 962 four bolt main block.
Old Sep 15, 2023 | 06:47 PM
Greg's Avatar
Greg
I did not know this gb. If I'd seen this block at a swap meet, I'd have probably passed right over it. Thanks for the info.
Old Sep 15, 2023 | 07:55 PM
Nowhere Man
and a Chevelle aficionado like my self would study it and be all over it. This block is a month early for my car.
To nicely done restamp
