Metal Fuel Filter
Old Oct 28, 2023 | 07:26 PM
miked123's Avatar
miked123
Default Metal Fuel Filter
I would like to replace my inline GLASS fuel filter (between mechanical Pump to Quadrajet Carburetor) to a metal one. It needs a 3/8ths IN and I want to swap it out. Any Recommendations? If y'all have any photos of your set up and part numbers/links to where y'all got filters let me know!!
https://www.corvetteforum.com/forums...-question.html
Old Oct 28, 2023 | 09:46 PM
lowbuck72's Avatar
lowbuck72
I'm, surprised, I have a glass, cleanable in line filter and I couldn't be happier with it. It's easily serviceable, will last forever, and I like that you can visibly see when the carb is getting fuel.
Old Oct 29, 2023 | 12:33 PM
miked123's Avatar
miked123
I understand. In a previous post I made yesterday morning (has pics of location) it is in a bad location for me. It is in between the valve cover and the AC compressor bracket. One small slip and it breaks……also a pain to replace too…I’d rather switch to a metal one and keep the old hose on there.
Old Oct 29, 2023 | 11:41 PM
lars's Avatar
lars
Your '74 Vette does not use an in-line filter. Get rid of the silly inline filter and install the correct steel one-piece fuel line from pump to carb - get rid of that horrible rubber fuel line. The fuel filter is in the carb and is more than adequate to do all the filtering tasks needed.
Lars
To Metal Fuel Filter
