Power Window Relay fix
Old Dec 11, 2023 | 05:34 PM
66RAY's Avatar
66RAY
Default Power Window Relay fix
Just thought I'd post my repair of the power window relay on my 73 project. Watched the Willcox video and tested the relay which did not work (no click). Took it apart and as noted in the video as a possible problem the tiny ground wire soldered to the inside of the case had come apart. Spliced in a very thin wire and soldered to the case. Reassembled and voila a working relay.
