Differential numbers
Old Dec 31, 2023 | 03:43 PM
kansas123's Avatar
kansas123
Default Differential numbers
I located these on the bottom of my diff, wonder if they are enough to tell anything about it. On a '72 350 automatic. Thanks
(PS, might be missing some) AW 116 E12
Will do some more googlin' in the meantime
Old Dec 31, 2023 | 04:03 PM
n2h2o2's Avatar
n2h2o2
AW = 3.08
116 = day of the year (April 25)
E= Eaton plant
12= should be the shift so maybe this was built on both 1st and 2nd shift?
Old Dec 31, 2023 | 04:24 PM
kansas123's Avatar
kansas123
I really really REALLY appreciate that information Nitrous!
Old Dec 31, 2023 | 08:50 PM
69L88's Avatar
69L88
Originally Posted by n2h2o2
AW = 3.08
E= Eaton plant
It is my understanding that all of the differentials were assembled at the Warren, Michigan plant and the E is indicative of the positraction unit which were manufactured by Eaton.
Old Dec 31, 2023 | 09:09 PM
n2h2o2's Avatar
n2h2o2
Yes, I believe you are correct...
I think they dropped the "W" for Warren somewhere in 69 or 70...
E is for Eaton Posi unit...but they were still assembled at Warren.
I don't think there was another build plant. (I could be wrong?)
But I never understood why they dropped the W and kept the E since they were all Eaton Posi's after 70...?
Old Dec 31, 2023 | 10:55 PM
69L88's Avatar
69L88
This is a case I currently have from a 73 I bought a while back specifically for the 3rd gen posi. The extra W is for the Warren plant.
I have seen other differentials without the W but have not seen one with a “12” as the OP states.
I have no proof one way or the other but I presume the Eaton posi units were “loaded” by Eaton and the subassembly sent to Warren for installation into the differential.
Old Dec 31, 2023 | 11:21 PM
n2h2o2's Avatar
n2h2o2
You are right...I have a pumpkin from a 74 that has the W and the E...
I am sure I read that they dropped the W at some point...
Now you have me curious to find out why / when there is some without the W...
Yeah...The 12 was new to me as well...
Old Dec 31, 2023 | 11:31 PM
kansas123's Avatar
kansas123
And I am pretty sure mine is AWW also, I had suspected I as missing a digit or two. I can double check that tomorrow if we go above freezing.
Old Jan 1, 2024 | 03:05 PM
DWAVette's Avatar
DWAVette
My 75 has the following:
O A W 282 F 1
for comparison purposes.
I have a L48, 4-speed. I am not sure of the meaning of the markings, but listed them as another example of markings.
Old Jan 1, 2024 | 03:26 PM
n2h2o2's Avatar
n2h2o2
O A W 282 F 1
OA is listed as 3.08 for 1976 and 1977.
Perhaps you have a very late production 75, or the diff was changed at some point.
check your casting dates, especially on the main case.
As previously mentioned, the W is Warren , the 282 is the day of the year( check casting date)
the F is probably a light stamped E for Eaton, and the 1 is first shift.
Old Jan 2, 2024 | 11:38 PM
Stick To Your Gunz's Avatar
Stick To Your Gunz
You guys are like the CIA of Corvettes!!!
To Differential numbers
