Timing Chain Replacement
Old Jan 4, 2024 | 07:32 PM
  #41
jpatrick62's Avatar
jpatrick62
So I pulled off the old crank gear and put on the new on and this is the test fit for the new DR timing chain. I haven't torqued down the cam gear bolts nor put on threadlocker blue yet.
Looks aligned, but if anyone sees anything amiss, LMK...
Chain is tight, was a bit of a struggle to get the cam gear on. I plan on taking the cam bolts out one by one and putting threadlocker blue on them and then I'll torque all 3 down.
Old Jan 4, 2024 | 07:56 PM
  #42
interpon's Avatar
interpon
Soak in oil?
Old Jan 4, 2024 | 09:10 PM
  #43
jpatrick62's Avatar
jpatrick62
Originally Posted by interpon
Soak in oil?
No, I just wanted to test fit it - would soaking it have made fitting it on easier?
Old Jan 5, 2024 | 07:39 AM
  #44
HeadsU.P.'s Avatar
HeadsU.P.
No. interpon is saying, never final install dry.
It takes a while for oil to drain from the lifter valley down onto the chain.
I still like to see a cam bolt locking plate installed but that's just me, over cautious.
Your alignment is TDC cyl #6
Old Jan 5, 2024 | 01:21 PM
  #45
wwiiavfan's Avatar
wwiiavfan
Next time you need to turn the crank with the balancer removed, there is a socket for that to slip over the crank snout. Should be available lots of places, even locally. Probably could even rent one.
Old Jan 5, 2024 | 06:49 PM
  #46
riverracer au's Avatar
riverracer au
I like that about over there in the US, need a tool for a one off job, just rent one from local autoparts place... use it, then return it.
Down here in OZ, you would have to buy it, (with corvette tax added), use it once and stash in back of toolbox, they don't rent out tools here.
Luckily I'm a Toolmaker, so I just make what I need at work.
Old Jan 5, 2024 | 10:24 PM
  #47
jpatrick62's Avatar
jpatrick62
Today I ordered a Cam Locking Plate for a SBC off Amazon. Could not find one at Napa or other auto parts dealers.
Old Jan 5, 2024 | 10:28 PM
  #48
jpatrick62's Avatar
jpatrick62
Good to know - Autozone has a ton of free rental tools.
Old Jan 6, 2024 | 08:15 AM
  #49
HeadsU.P.'s Avatar
HeadsU.P.
Yes, that's not something kept in stock, because of high demand.
Good for you, however. That part is inexpensive insurance. Loctite is a wonderful product, but not 100% guaranteed.
As I recall, there are three bendable tabs per bolt. You only need to bend one or two of the tabs per bolt.
Plus a drop of Loctite Blue and you are good to go.
(oil the chain)
Old Jan 6, 2024 | 08:18 AM
  #50
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I would think that for the cost of renting one of those sockets, you could spend $2-3 more, and buy one. Then you have it for future use.
