Timing Chain Replacement
timing marks jumping around when trying to time it, occasional backfire, shuddering, etc. The chain looks original and has major slack in it so it's a good thing I did this. I do have a few Q's for
some of the more experienced motor heads in here though. I aligned this to TDC firing on #1 plug, but in retrospect maybe I should have done this on #6 so the cam and crank marks were closer.
As it is, I cannot easily move the crank and am afraid to put the bolt back in and try to get them closer as I didn't want to accidently twist off the bolt in the crank.
1. So is there a proven way to turn the crank at this stage (balancer and pulley off)? If not, does this look aligned to you?
Does this look as if the crank and cam dots are aligned properly?
2. Should I swap out the oil pump now as I removed the oil pan? Is swapping out the oil pump essentially a bolt on process?
3. I had to unbolt the idler arm to get the oil pan to clear the steering arm (to take the pan off). Is there a better way for future reference?
Thanks for any help!
The dots seem to line up, but the cam and crank sprockets are a tad off....
I would leave the oil pump alone unless it was giving you a reason to change it. The pickup will need to be installed (pressed in) and the clearance to the bottom of the pan needs to be set. Best practice is to braze the pickup in place once it has been installed but you need to disassemble the pressure regulating valve before you heat it up to protect the spring so..... maybe just leave the pump alone if it still works?
Removing the 2 bolts for the idler arm to the frame is pretty simple and quick and requires no pickle forks or joint separators.
If you do order the plate, throw some Comp Cams break-in oil on the chain too.
And if you do remove the oil pump for inspection, by all means upgrade the driveshaft also.
But If you are thinking of it you may as well do it, no better chance than the present. just measure the pickup off the other pump and get it close, bolt it together and then tape a loose ball of aluminum foil on the pickup and push the oil pan into place. Pull it apart and see how much gap you have. Adjust it as necessary and just put 2 tack weld on it, no need to get fancy. When you pull it apart that drive rod will come out. Once you get everything correct swap the new pump drive in. Its not difficult.
i just want to get a reliable driver that starts and runs well. I will send out the original balancer to DamperDoctor but other than a DR timing chain and new water pump, everything else is stock. Oh, and I will paint all the parts and use a one piece oil pan gasket.
The oil pump has only one mounting bolt. Once removed, the pump & old shaft will drop down & out.
If you are not into welding a pickup screen on a new pump, Jegs sells a bracket that clamps onto the pickup tube. The bracket bolts onto the pump cover / housing.
Very simple, no welding, super strong and the pickup tube angle is still adjustable should you change your mind later. Once you weld a pickup in place, you are committed to the angle you chose.
Some people would say: "only a fool would not swap the pump & shaft while the pan is off".
Others would add; only a fool would not change the rear main seal while the . . . . . .
So, as you can see, you can go on & on & on with this project.
Only you know the mileage, the history of the car and the condition of the pump, the size of your wallet.
Fortunately, all these parts are fairly cheap.
I would like to add, if funds are available: only a fool would ever reinstall oil pan bolts.
After being introduced to an Oil Pan Stud Kit, it's the only way to go. (especially when laying on your back on concrete with a One-Piece gasket)
of some oil seepage.
