instruments gauge lights doesn't work
Old Feb 10, 2024 | 01:29 PM
dru77's Avatar
dru77
Default instruments gauge lights doesn't work
Good morning all,
I have a C3 '69 with a strange issue.
My park lights, interior lights, and headlights all work. All fuses are OK, and all dash lights works if I remove them from the bezel
when I connect the bezel with the back no lights works. all gauges works correctly
I guess is a problem with the ground when all the bezel is completely connected to the platform with the gauges+instrument lights
any ideas on why dash lights won't work when connected to the bezel?.
thank you and sorry for my english
ludovico
Old Feb 10, 2024 | 04:25 PM
Bikespace's Avatar
Bikespace
Try turning the dimmer, and see if a different position fixes the problem.
The dimmer is inside the headlight switch, so turn the ****.
Old Feb 10, 2024 | 06:10 PM
robertea's Avatar
robertea
If you are missing a ground to the gauges the lights will not function as there is only one wire to each bulb. There should be a ground lug on each piece of the gauges. They might not be in the same location as the photo, but as long as they are there you should be good.
There also should be a ground wire attached to the birdcage frame with a star washer. These would be the first two things that I would check. The headlight switch also has a ground strap attached to it.
Old Feb 11, 2024 | 06:56 AM
dru77's Avatar
dru77
thank you very much!!!!
really appreciate. it was enough turning the dimmer to have light! I would never have solved it without you because I had no idea the dimmer existed
now, all works: gauges, lights, radio....
thank you again and a big "ciao" from Italy
To instruments gauge lights doesn't work
