Wont turnover
Old Feb 20, 2024 | 07:05 AM
bbillman01's Avatar
bbillman01
1st Gear
Default Wont turnover
I have a '78 that when I turn the key and try to start - there is no sound. Battery has 14.2 cranking amps, I replaced the starter and it started several times and now nothing. I can jump it from the solenoid and it starts fine. Does not seem to be heat soak or the neutral switch. Thoughts ?
Old Feb 20, 2024 | 08:31 AM
HeadsU.P.'s Avatar
HeadsU.P.
Does your starter have a front support bracket? Most years did and several of those brackets were never put back on after the starter was worked on.
The bracket went from the starter casing to the block. It not only serves to take some weight off the starter bolts, but is also an excellent GRD.
And of course, you must put the rear tires on ramps, remove the Battery NEG GRD cable at the frame. Wire brush everything, reinstall.
The great (not) invention of the side post terminals on batteries could easily hide poor contact, corrosion, etc.
Old Feb 20, 2024 | 10:15 AM
MelWff's Avatar
MelWff
Using a voltmeter and a helper, connect the meter to the S terminal of the solenoid and have the helper turn the key. No power is bad switch or break in wire from switch.
Old Feb 21, 2024 | 05:22 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Starter harness has a connector on the firewall just passengers side of the distributor on my 77. Plastic connector for the starter solenoid wire. Mine gave up a few years ago. No start. Repaired that connection. No issues ever since.
Old Feb 21, 2024 | 07:52 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Didi you check ignition switch, ignition switch adjustment, neutral safety switch, starting wire to solenoid fusible link, if its a four speed the clutch safety switch?
To Wont turnover
