Did I make a mistake?
A couple things I learned about these guys, first off don't ever pay their price. I had this one shipped from Orlando to SLC and ended up just south of $17K including shipping. Still high but where else you going to find a low mileage, all original black/red L82 automatic with a factory CB? Also, they left the ad and video up for a couple weeks I presume to get more people calling so they could get a chance to sell them on something else. No regrets at all.
https://www.gatewayclassiccars.com/v...-corvette-l-82
The Carvana offer on her minivan is back up to $11k and now she says it isn't fair that I have a 2022 Charger RT and she has a 2016 minivan. She wants a Durango and found a loaded 2020 with 32k miles for $28k.
That car needs some things, to be sure. Like a new interior. Power steering leaks, but they all do. That system can be eliminated or replaced.
There are no pictures of the actual rust problem areas. But what it does show underneath, is not really concerning. I only saw surface rust.
Under the hood, there are indications that half of the problem with that car (CCC and dist) have been eliminated, but I'd confirm that with the seller.
If the paint is better in person than it looks in the photos, that car might make a fine restomod, at the right price. But as it sits, it needs everything.
Why shouldn't you buy an 81 as a first-time Corvette buyer?
For all the grief that the 82's Crossfire system gets (rightly or wrongly), the 81's computer controlled carb and non-vacuum distributor is worse. It needs a paperclip, or a very specific instrument, to read the codes. It is NOT tunable to any great degree, and you are better off reverting to a previous year's Q-Jet and dist, or swapping to a Holley (which may require an intake manifold change), or EFI. If the PO already did this for you, great! But I BET THEY SCREWED IT UP, and that's why the car is for sale in the first place (that, and the automatic transmission). So right out of the gate, you'll likely need to fix the car to make it run properly. No problem for lots of folks on this Forum, but most buyers will spend thousands at a mechanic, who will just screw it up more, and the car will be back for sale again soon.
This is all fixable, and if you know what you are doing, a clean 81 would make a great restomod. But not as your introduction to Corvettes and classic cars, and certainly not if you will rely on a local mechanic to do the work.
As for the auto vs. manual question:
There are lots of boring, soul-less automatics on the road, and in rental pools. GM stopped making sports cars, and this year is the last for the Camaro. If you want a pretty car to drive to car shows or drone along at one speed on the interstate, a C3 with a TH350 is fine. But it is a terrible transmission. My 80 with a 4-speed is (no hyperbole!) ONE MILLION TIMES more fun to drive than my 79 auto. Both have the same L48. The only important difference is the engagement in the experience of actually driving the car.
I have owned two C3’s, one C4, and one C5. I am a flip-up headlight guy. Not interested in non-flip up generations.
Each generation has its own quirks. If you are afraid of a C3, then don’t buy a problematic C5! The C4’s are also great. Easy to work on, handle well, but are very tight inside with high door sills. They are drastically different over the generation, but have specific problems.
C5’s are awesome to drive and look great Very comfortable. Note they did not come with spare tires, but with run flats. Two fuel tanks, one fuel pump and one Jet-Siphon pump - try understanding how that system works. There are numerous computer modules throughout the car that can drive you crazy when malfunctioning.
Flip back and forth through the Tech section of each generation you are thinking about.
You may end up with a C8!
Good luck. Get one!
Luckily you got that cancelled.
Next time put the pictures up here first so folks can comment. There is no hurry ..
There millions of C3s out there and the folks here have a lot of knowledge to assist in your decision making. .
Your profiles has no info. Depending on where you are I would tell you NOT to get that car since it would never pass smog on top of everything else.
