Fuel Pump - Will it pull?
Old Mar 12, 2024 | 12:44 AM
K-Dog's Avatar
K-Dog
Default Fuel Pump - Will it pull?
I have a base 71 350 that has been sitting a while. I’m pretty sure the fuel lines are empty from the carb to the tank. If I put gas in the tank, will the pump pull it all the way to the carb? Does the system need to be “primed?”
(Tank is new, so it’s been completely empty for months.)
Old Mar 12, 2024 | 12:55 AM
Greg's Avatar
Greg
Just another Corvette guy
The original style mechanical pump is a good puller. You should not have to prime but it wouldn't hurt to fill the carb so you don't have to go through an extended cranking period.
Cheer, Greg
Old Mar 12, 2024 | 03:59 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
100 percent.
Old Mar 12, 2024 | 08:42 AM
HeadsU.P.'s Avatar
HeadsU.P.
Brand new tank, zero crud, that's excellent.
I think I would put a few gallons in the tank. Try to jack-up the rear a tad.
Then disconnect to feed line at the pump, from the tank just long enough to get some flow into a bucket, reattach.
I would not allow the pumps diaphragm to operate dry very long. So yes, basically prime it.
Old Mar 12, 2024 | 08:45 AM
HeadsU.P.'s Avatar
HeadsU.P.
Then disconnect the feed line at the pump from the tank, just long enough to get some flow into a bucket, quickly reattach.
You may get some syphoning from the tank, may not. Try it.
Old Mar 13, 2024 | 03:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
On the ground and level with a half tank of gas....pulling the supply line will yield a steady stream of fuel. If it doesn't, then you have a blockage (bad sock, collapsed hose at the sender, etc...).
Jebby
Old Mar 13, 2024 | 04:50 PM
K-Dog's Avatar
K-Dog
Thank you everyone.
The pump pulled just fine after a few turns of the engine. I have the car pretty much level with about 4.5 gal in the tank.
To Fuel Pump - Will it pull?
