Electric water pump dependability?
Old May 11, 2024 | 02:27 PM
Tech141's Avatar
Tech141
Default Electric water pump dependability?
I am in the process of planning out my 406 build, and am 'kind of' considering using an electric water pump. I know there are a good amount of choices out there, but not sure of their dependability. Is anyone running an electric water pump on your daily driver? If so, what has been your experience with them?
Old May 11, 2024 | 03:26 PM
Mdbirk's Avatar
Mdbirk
Meziere 300 Series is good but on the street....well it's up to you. I know some have never had a problem and some who have.
Old May 11, 2024 | 11:40 PM
Eric P's Avatar
Eric P
I’ve had a Mezerie on a 63 Fairlane FE engine since 2000 with no issues
Old May 12, 2024 | 11:05 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
what are your options if it breaks on the street.....only reason I dont have one, but an electric fuel pump will leave you just as stranded and I run one of those. I did almost get stranded once but was able to limp it home as it was just starting to fail. Dont know if you would notice the signs of a water pump slowly going bad
Old May 12, 2024 | 11:17 AM
Tranz Zam's Avatar
Tranz Zam
I've run multiple Mezerie pumps on the street with no issues.
Old May 12, 2024 | 12:21 PM
sunflower 1972's Avatar
sunflower 1972
IMHO, you use an electric water pump to extract every ounce of horsepower from the engine. Great for quarter mile racing. If the car is just a street cruiser, why?
Old May 12, 2024 | 01:26 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
for what its worth, about 20 years ago a very good mechanic talked me into not using an electric pump or electric fans on my 383 78 pace car restoration in south florida where i was living at the time. he told me that with an aluminum radiator and the proper manual fan and functioning fan clutch, the car wouldn't be subject to electrical or mechanical cooling failure. i admit i was very hard to convince, but i agreed to replacing the original tired radiator with an aluminum one and went with the OEM cooling fan set up. the car wasn't for the drag strip, it was used as a cruiser and a street vehicle. i have to admit that i was completely flabbergasted, sitting in dead stopped, and bumper to bumper summer traffic for the first time, watching the temperature gauge anxiously, that i was amazed that the car water temperature never rose above 195 degrees. i never had a cooling issue with the car for the 12 years that i owned it after it was completed and drove it in the summer time in south florida. it was engineered not to blow it's stack, and it performed as designed (with the help of the aluminum radiator). it all comes down, in my opinion to having a well maintained vehicle.
Old May 12, 2024 | 02:06 PM
C3 Stroker's Avatar
C3 Stroker
I've had a Meziere electric water pump for at least 5 years with no problems. Street/strip car that doesn't get driven much but no issues. Meziere says about 10,000 hours or so and the pump should checked or serviced, but at my rate that would be about 15 years or so. You would be just as stranded if your mechanical water pump failed, so that is not a concern. Many hi-perf cars in my area run electric water pumps with no issues on the street........but all say Meziere is the best and most reliable.
Old May 12, 2024 | 02:28 PM
sunflower 1972
Sorry, but I humbly disagree with that statement. Unless you have a catastrophic event with the mechanical water pump, (highly doubtful), all it would do is start leaking, probably out of the weep hole. Stop and get a couple of gallons of water, you'll get home.
Old May 12, 2024 | 09:29 PM
C3 Stroker's Avatar
C3 Stroker
I've had leaky mechanical water pumps before as you described......I hardly call that a failure......but a warning......like a slow leak tire. That may not strand you. A true failure would. But, no, electric pumps are not for 100,000 mile expectations.........neither are 680 hp small blocks like mine.
To Electric water pump dependability?
