Jack stands
Old Aug 17, 2024 | 12:08 AM
ffarina's Avatar
ffarina
Default Jack stands
Where do I put jack stands on 1982?
Old Aug 17, 2024 | 01:28 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
In the back, in front of the rear wheels you will see a triangle shaped reinforcement just forward of the rear wheels. In the front, below the forward part of the door. Just as the frame becomes level.
There is a very good diagram in the service manual showing jacking points and stand/lift points.
Assuming you don't own a service manual.
Do yourself a huge favor. Purchase a genuine GM Manual.
Old Aug 17, 2024 | 10:07 AM
robertea's Avatar
robertea
Here is the image used in the 69 Owner's Manual. The frame is basically the same. Once I set the jack stands, I always add two more at the front of the car since there is a lot of weight on the nose of the car. I would rather have additional support to ensure that nothing can happen while I am crawling around under the car.
Old Aug 17, 2024 | 11:38 AM
Mark G's Avatar
Mark G
It's kind of awkward to get a C3 up on Jack stands. I would suggest a 5th jackstand under the front to keep the front end from drooping (which *could* crack aged or weak rear fender bonds (where they adhere to the birdcage).
Old Aug 17, 2024 | 12:19 PM
sunflower 1972's Avatar
sunflower 1972
Old Aug 17, 2024 | 04:21 PM
ffarina's Avatar
ffarina
Originally Posted by sunflower 1972
Thank You !
ffarina's Avatar
ffarina
Thank You !
Old Aug 17, 2024 | 04:22 PM
ffarina's Avatar
ffarina
thank you
ffarina's Avatar
ffarina
Thank You !
Old Aug 17, 2024 | 04:23 PM
ffarina's Avatar
ffarina
Thank You !
Old Aug 17, 2024 | 04:24 PM
ffarina's Avatar
ffarina
Thank you!
Old Aug 17, 2024 | 09:17 PM
bagger327's Avatar
bagger327
2025 C3 ('68-'73) of the Year Finalist - Unmodified
On my '79, if I wasn't working on suspension, I put a set of ramps facing outwards for additional support. Seen it on Dave Kindig's show. Worked pretty slick.
Old Aug 17, 2024 | 10:09 PM
ffarina's Avatar
ffarina
not sure I follow, facing out where exactly ?
To Jack stands
