Holley Fuel Regulator Problems
Old Sep 29, 2024 | 09:38 PM
Brown Bandit's Avatar
Brown Bandit
Default Holley Fuel Regulator Problems
Seems like i cant catch a break with the new parts ive been purchasing. 1st i had a new fuel sending unit go bad after 2 weeks. Now my Holley regulator is not working. Both parts were installed back in March so both are out of warranty. I had the regulator set at 5.5 psi and car was idling awesome. Finally got around to installing my lock up kit for the 700r4 yesterday and car wouldnt start. Had a bad smell of gas and found that the carb was flooding. Well it turns out the regulator was not regulating the fuel anymore. The car has never seen the road and was probably only started 10 times and let idle for 10 minutes each time. So i took off the regulator this morning and opened it up thinking the diaphram must be torn, but it wasnt. Looks to be in really good shape. Could the regulator have gotten stuck? Tried adjusting while on car but no change at all. Has anyone experienced this type of issue with holley regulators? What could have caused this?
Old Sep 30, 2024 | 08:14 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
The $50 or less regulators are hit and miss. They seem to fail for no reason. I bought one for $60+ and it seems easier to adjust, but not great. I'm guessing the inexpensive ones are designed to fail so we'll dump $100-$200 in a dependable regulator.
Old Sep 30, 2024 | 08:22 AM
Brown Bandit
I guess the one i bought was a mid-level on Model#12-881. Still confused as to why its not working. Internals look brand new cause it literally is a brand new part.
Old Sep 30, 2024 | 08:33 AM
1860army's Avatar
1860army
Old Sep 30, 2024 | 05:10 PM
MelWff's Avatar
MelWff
Did you measure the pressure?
If you have dirt on the needle and seat in the carburetor it will flood regardless of pressure.
Old Sep 30, 2024 | 07:15 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The needle and seat stick more often than not on Holley carbs, not sure about quadrajet. If you tap the fuel bowl lightly on top of the adjustment screw on a Holley it will usually pop free and not be a problem for quite a while
Old Sep 30, 2024 | 09:19 PM
Brown Bandit
Its an Edelbrock 1405 carb.
Old Sep 30, 2024 | 09:23 PM
Brown Bandit
The fuel gauge is right after the regulator and it maxes out. The day before i had it set at a consistant 5.5 psi and idling perfect. I have an edelbrock carb.
Old Sep 30, 2024 | 09:24 PM
Brown Bandit
Old Sep 30, 2024 | 09:59 PM
HeadsU.P.'s Avatar
HeadsU.P.
In defense of Holley, I have never had a needle valve stick in decades of service.
Had float with pin hole sink.
Old Oct 1, 2024 | 11:32 AM
Brown Bandit
Are we talking about the regulator? Cause this particular regulator has a diaphram with a roller ball at the bottom of it.
Old Oct 1, 2024 | 11:39 AM
doorgunner's Avatar
doorgunner
I think he is talking about the Holley carb needle and seat.
I really think something is wrong with the design of the cheaper Holley fuel pressure regulators.
Old Oct 1, 2024 | 11:54 AM
PBF777's Avatar
PBF777
The old Holley #12-803 regulators of a couple of decades ago and further back were trustworthy and not expensive, everybody used them and generally without issue; now though, I don't believe they are manufactured here in the U.S.A. anymore, and unfortunately we can no longer expect the past history of reliability from the new product.
Scott.
Old Oct 1, 2024 | 04:17 PM
Brown Bandit
Scott.
So basically I am SOL with this part? So these parts get more expensive, shittier quality, and have warranty that aint worth a damn. Well is there any regulators that anyone can recommend. Need to get my car back on the road already. The heat has let up in Tx and i need to go for a cruise.
Old Oct 1, 2024 | 06:41 PM
Rescue Rogers
I had a couple of Holley regulators. ONe was supposed to be for high pressure EFI elctric pumps with a bypass, it didnt work out of th ebox an dI sent it back. Had another that wouldnt go low enough as advertised, sent it back. Had one that was for low pressure and it was working great but want to have a bypass regulator, thats whats in it now with a return line and it works great so far. I think its a more expensive one
Old Oct 1, 2024 | 08:18 PM
Brown Bandit
Well the one i have was $75. Is that considered on the cheap end? It was recommended by a few people.
Old Oct 1, 2024 | 08:22 PM
MelWff's Avatar
MelWff
You have an Edelbrock carburetor use the Edelbrock regulator they recommend
To Holley Fuel Regulator Problems
Old Oct 1, 2024 | 08:25 PM
Rescue Rogers
Those are right in the middle, my last one was the 842 which is $165. It has an idle bleed which let's the pressure drop at idle so I don't blow past the needle....I like it.
Old Oct 2, 2024 | 10:01 AM
Street Rat's Avatar
Street Rat
I quit using Holley regulators.
I use Aeromotive pumps and regulators.
Craig
Old Oct 2, 2024 | 11:33 AM
PBF777's Avatar
PBF777
Poor quality product is not solely an issue to be attributed to the Holley brand, it's everywhere, as 'cheap' is what the buyers are lunging for first most often, and the manufactures/retailers are forced to respond to this whim. But yes, as stated previously, if you just move into the $150.00 (and up!) range these products do generally become significantly better.
And of course, purchasing the correct application product always helps too.
Scott.
