Ignition Coil
Old Oct 10, 2024 | 05:32 PM
mbp's Avatar
mbp
Default Ignition Coil
Hello. My 69 s.b. has and an electronic ignition that was installed about twenty years ago, as to the P.O. work orders, works good no problems.. Perhaps a Pertronix brand, hard to read the work order. It may not make a difference as to my question. I need a new coil due to a crack on the top of the one that is now in the car. Thought of going with a Pertronix one. The vendors list different versions of the Pertronix flame thrower coil. The difference being the ohm. resistance, either 1.5 , 0.6 or 0.32 . Not sure what that means in the actual running of the car and what difference it would make? Can someone explain and advise on which would be good for a stock s.b. Thanks in advance.
Old Oct 10, 2024 | 06:04 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
here you go
https://www.motortrend.com/how-to/ch...ignition-coil/
I would go with the highest volt output so you can run .045 plug gap.
I have a 50k coil, accell, thru resistance power wire using points.
no degradation of points.
Old Oct 10, 2024 | 07:59 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by calwldlife
here you go
Respectfully, the 50kV rating is for the dielectric/insulating capability of the windings. It has no connection with the voltage that actually comes out of the secondary terminal. The plug gap width and the cylinder pressure at ignition time determines the peak secondary voltage. The coil secondary voltage merely ramps up until it hits that required voltage, and then clamps at the voltage needed to keep the arc going until the coil energy is depleted. And following the "No free lunch" rule, the wider the gap the shorter the arc time. It's like emptying a five gallon bucket of water. You can empty it fast or slow, but either way you're only getting that same five gallons out.
peters220's Avatar
peters220
Start by measuring the primary resistance of the coil you are replacing. If it was performing normally, replace it with a similar resistance coil.
Old Oct 10, 2024 | 08:55 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
ok,
Old Oct 10, 2024 | 09:26 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
ttt
Old Oct 10, 2024 | 11:47 PM
68blvert's Avatar
68blvert
Doesn’t matter if you have a coil rated to a bazillion zolts, it’s only gonna put out what’s required to fire the plug. If the plug needs 10,000 volts to overcome cylinder pressure/ circuit resistance , that’s all it’s gonna draw. A coil that supply’s the energy of a particular engine’s needs reliably is all that’s required.
Old Oct 11, 2024 | 10:26 AM
jhudec's Avatar
jhudec
Why not just use an original BR 270 coil?
Old Oct 11, 2024 | 10:51 AM
mbp's Avatar
mbp
Thanks for the replies. Didn't know what would of been original. Where would a BR 270 coil be available. Was trying to avoid a generic brand, hoped for a bit better quality, even though I'm sure they all come from the same far away place.
Old Oct 11, 2024 | 11:24 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
NAPA Echlin brand coils are made in Poland (last I read); NGK coils are made in different locations, but I trust their quality and have them on both of my cars -- ain't inexpensive though. (Be careful buying any ignition components from eBay -- if the price seems too low, it could well be counterfeit.)
Whichever coil you install, make sure you have an air gap between it and the manifold of 1/4"-1/2" – coils don't do well with heat.
Old Oct 11, 2024 | 11:35 AM
peters220's Avatar
peters220
In mpb's situation the coil resistance probably matters. His ignition system is unknown. The electronics probably require a specific resistance range. To low and the system will probably fail. JP
Old Oct 11, 2024 | 11:48 AM
barkingrats
Since the module is unknown and old, maybe install a new module and coil from Pertronix (have never read about other brands, everyone just references Pertronix 🙂). Start with fresh and known.
The installation instructions for the PerTronix 71181 Ignitor® III Delco 8 cyl specifies .32 ohm or greater.
Old Oct 11, 2024 | 11:54 AM
jhudec's Avatar
jhudec
Post a want to buy here on the forum.
I may even have a good used one. I have a 69 L46 and 72 LT1, both use the same coil.
Also, should be on the large auction site.
Make sure it has been tested good.
Joe
Old Jan 6, 2025 | 10:04 PM
QIK59's Avatar
QIK59
What colour is your coil : black or chrome ?
What colour is the top - insulator part of the coil ?
That will tell me whether OEM/replacement type or aftermarket / performance coil and possibly what mfr ?
I went through a coil testing episode a number of years ago and learned that the only domestic (Andover, OH) mfrd coils had a segmented crimp can - (at the top of coil) - irrelevant now - Andover coil plant gone
I bought every chrome segmented crimp can coil I could find - Pertronics coils were not a recommended coil at the time.
As Peters220 said - take your coil to someone with a good (precision) ohmeter and have the primary resistance checked then find an coil with similar primary resistance or greater.
Old Jan 7, 2025 | 08:02 AM
pigfarmer's Avatar
pigfarmer
Old Jan 7, 2025 | 11:10 AM
QIK59's Avatar
QIK59
I can't be bothered to watch a You Tube video because most of them are a "how to" for dummies / nothing learned.
Can you elaborate what tests are performed and what one actually learns from this video please ? Thank you
I believe the OP coil is functioning fine ?
He just wants to replace it with an appropriate/equivalent coil - asking for assistance in determining what coil he should be looking to buy
Old Jan 7, 2025 | 11:49 AM
pigfarmer's Avatar
pigfarmer
I posted that video because it's painfully simple and if you've been at this since October then two minutes and forty three seconds seems a bargain to have your answer.
The primary winding is measured across the two + and - posts on the coil. Polarity doesn't matter. The resistance across those two posts should be in the range of 0.4 ohms to 2 ohms. The secondary winding is between one of the two small + or - posts (doesn't matter which) and the center post. Resistance should show between 6 Kohm and 20 Kohm. The video explains that and how to use a multimeter very, very clearly. I took the time to find it for you because I am trying to help, please take the time to look at it.
Personally, I agree with you about videos but sometimes they are just so obvious it's worth it. This one is really short and very clear.
If you're going to go to a parts store save yourself the trouble and bring a meter and test it right there. There is zero danger to the coil, you won't ruin it or anything. It'll take maybe ten seconds. If they're in that range they're good enough for stock engines, you don't need an expensive super duper ultra spark coil, you just need one that works.
To Ignition Coil
Old Jan 7, 2025 | 12:42 PM
QIK59's Avatar
QIK59
Default Thank YOU !
The primary winding is measured across the two + and - posts on the coil. Polarity doesn't matter. The resistance across those two posts should be in the range of 0.4 ohms to 2 ohms. The secondary winding is between one of the two small + or - posts (doesn't matter which) and the center post. Resistance should show 6 Kohm and 20 Kohm. The video explains that and how to use a multimeter very, very clearly. I took the time to find it for you because I am trying to help, please take the time to look at it.
hI Mr Farmer,
I am glad you understand where I'm coming from.
Also glad to hear the video is only a couple of minutes long - my "concern" was how long would someone have to watch / listen to find out how to clip on a couple of test leads and look at a meter LOL
I am not the original poster (October) I am probably too late to the "party" with my post.
Thank you for your good will and good intention for the OP
I have reached out to someone I was in contact with 11 years ago, who "knew" the quality and origin of most 12V round coils, to pick his brain as to "where things are at" these days for quality coil availability.
If the original poster replies we'll see where things go with our good intentions LOL
Jerry
Old Jan 7, 2025 | 01:36 PM
pigfarmer's Avatar
pigfarmer
These posts seem to stay around forever and you never know who will be reading what from where.
I'm retired and thought it might be interesting to work at my local AutoZone up front, not in their commercial dept. It wasn't. That part is just a retail outlet no different than a Home Depot or whatever.
I was the one eyed man in the Kingdom of the Blind because I know how to use a meter. I didn't want to be The Man to dispense Advice because I am a putz not a mechanic and don't presume to be. But, if I know something from direct experience I might say something depending on who was asking.
For stock engines, for the most part, a coil's a coil's a coil. I was bored one day and had someone ask about this and was surprised to find one of the new replacements on the shelf was junk. He didn't know how to test it and I imagine that saved him some trouble. Probably a lot.
Meanwhile, I have a couple rolling around on my bench from the Early Jurassic period that have been in and out of a couple of vehicles for one reason or another and they're fine. I wonder if that can happen with the fancy super mega sparker ones ? Probably, quality control is spotty anymore it seems.
Old Jan 12, 2025 | 10:49 PM
QIK59's Avatar
QIK59
Default A year later ?
So I see where you started this " coil issue" a year ago testing your coil resistance because you had nothing better to do - "lots of spare time" your words.
Your car was running fine but you were curious and then after reading ambiguous specs for coils got wondering if your coil needed replacing.
On your latest coil quest inquiry people have given you information on how to test your coil resistance (you had done this already) and answering your question why you need to know the resistance value - let us know when you do something with the assistance given
