Engine choice help
Old Oct 20, 2024 | 01:46 PM
60 SHARK's Avatar
60 SHARK
Seems to me, a big question needs to be asked..
Are YOU doing any work on the engine/drivetrain?
If your paying someone to do the work, your not saving any cash. You likely have plenty of disposable income to spend on your projects. This is the type of customers I build cars for. So YOUR decisions and opinion are based on different parameters than most of us here on the forum..
So bottom line,, do the best you can afford and be content and happy with your choice .
Old Oct 20, 2024 | 01:51 PM
69L88's Avatar
69L88
Originally Posted by scuderia_kannan
I should add, the L82 and 4 speed both appear to be working fine, I just don’t think trying to road trip on a 48 year old drivetrain is very smart.
There’s a slight drip of coolant coming from somewhere that I’ll find next time I have some time.
The small block Chevrolet V8 is the most produced engine (>108,000,000) ever and is very, very reliable. Do a compression leak down check. I would do some common sense replacement of spark plugs, plug wires, and valve cover gaskets. Get a spare water pump and fuel pump for your long trips.
You have quite a few other areas other than the engine to ensure reliability. Check the differential axles for side play as they are notorious for excessive wear on cars in your vintage range. Check the wheel bearings for excessive play. Replace the front snubber bushing on the differential. Put in safety release hood release cables. Consider replacing the suspension bushings as they, if original, are likely rotted after all this time. Replace any rubber hoses in the fuel lines. Flush/replace the brake fluid.
Old Oct 20, 2024 | 01:53 PM
Mark G's Avatar
Mark G
Why don't you leave it as-is? It's been reliable for almost 40 years. IDK how you can beat that. Teach your son a bit of Corvette history and heritage (how they used to be). If you (I really mean..your son) can work on Carbs and simple ignition systems, it's a great place to start. Perfect learning ground. Learning the basics. Nothing more unreliable than a bunch of poorly-tested aftermarket parts from Asia ya can't get replacements for in 8 yrs.
Old Oct 20, 2024 | 02:32 PM
Eric P's Avatar
Eric P
L82 has 4 bolt main caps , forged steel crank , heavy duty rods , forged pistons , decent cam for factory stuff, all good parts from the factory, I would freshen the L82 if it really needs it , have the cylinder heads converted to positive valve seals and install your favorite port fuel injection and sell your carburetor to one of the guys on here that needs it
Old Oct 20, 2024 | 03:00 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
for the cost of the EFI and if your trying to gain MPG your going to have drive it tens of thousands of miles to get your money back. And correctly tuned a-jet will do very well for everyday driving.
Old Oct 20, 2024 | 03:30 PM
scuderia_kannan's Avatar
scuderia_kannan
What’s a ballpark estimate for how much it costs to do the kind of things you’re suggesting? Even just an order of magnitude helps to make a comparison.
I would say after building the Factory Five I feel comfortable taking out the old motor and putting a new one in, but I have no idea how to do anything with the internals.
I wasn’t planning on changing the motor right away, so what are some things that I can do right away for peace of mind? Replacing radiator hoses seems needed, but what other things should be on my list? (Things I can do quickly so that I can keep driving and enjoying it for now. Not things requiring pulling the motor)
Maybe I’ll build confidence in the factory setup over time. I would definitely put myself in the category of new hobbyists with little faith and familiarity in systems that we have since left behind. But I am very happy to learn and be educated by this forum, so thank you for the thoughts.
Old Oct 20, 2024 | 03:36 PM
Nowhere Man
Just drive the car and let the car tell you want needs to be fixed. Change the fluids and have fun with the car
Old Oct 20, 2024 | 04:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
long trips need an over drive trans,
regardless of engine.
L82 can be solid and dependable like any other
Old Oct 20, 2024 | 04:46 PM
scuderia_kannan
Yes I think no matter which engine I end up using I will be switching to a TKX with 0.68 5th gear (again unless there are other recommendations?)
Nowhere Man
why??? until the 80's when overdrive trans came out millions of people drove millions of miles and never gave it a thought. don't be spoiled by new cars. trust the simplicity of a old car
Old Oct 21, 2024 | 01:49 AM
Mark G's Avatar
Mark G
Changing the engine and swapping tranny's seems like a lot of work when a guy considers most C3 owners drive a couple hundred miles a yr....maybe 1200 on a good year. Ok maybe the first year you'll drive it more... less the second yr. Probably hardly at all after that. Sure ....some C3 owners drive theirs a lot. But they're the small minority. Just saying...
Yeah, drive it a while and see how it goes. Seems like a nice car. Learn up on the brakes before you dig into those. C3 Brakes are unique. And come with a whole host of 'best practices' ...that you might want to do some searches on. Cheers
