LS swap planning
If you are sure that the Billy Boat headers work, the 2004-2006 GTO manifolds look to exit at a very similar angle to the Billy Boat, I overlaid images to test. The C5 manifolds weren't close, neither were the truck logs (as you already mentioned). Where did you read the Billy Boat's work? It might be worth trying the GTO as a cheaper alternative.
And regarding your later comment about the clutch, I was planning on choosing the Luk replacement for the 1976 Corvette, which is 11". Some of the C5 part numbers from that thread are larger, which I'm not sure will fit.
I am sure the Billy Boat under-car headers work with the Z-bar. It is claimed by the manufacturer in this thread (Post 13). It looks like the sidepipe headers work, too.
https://www.corvetteforum.com/forums...h-quality.html
I don't know the answer to the clutch question. Have you checked your bellhousing? The SST bellhousing will fit my surplus LS6 flywheel, and whatever clutch I want.
I have the L82 engine and T10 transmission out and I'm working on cleaning up the engine bay and replacing anything that needs it while I have so much space to work. I'd like to redo the suspension while I'm in here.
I'm going from an L82, with AC, with Power Steering, to an LS1, without AC, without Power Steering.
What should I do for front springs? I'm assuming from my reading that whatever I do will involve cutting a spring down, is that correct? And if so, what spring should I start with? Rockauto has a lot of really affordable options:
And regarding shocks, are Bilstein B6's reasonable? I'm going to leave the rear stock for now but will eventually be replacing with mono spring, and I suspect I'll want Bilstein B8's back there.
Thanks.
On the other side of the spectrum if you really like spending money you could get coilovers.
Charlie
