Paint question
Old Nov 17, 2024 | 09:10 PM
Johnf692's Avatar
Johnf692
Default Paint question
I have a 69 with original paint. Recently had a short in my w/w motor and the plastic cover was in flames and I had heavy black smoke from the plastic settle on the top of my front fenders before I could put out the flames. I now have small plastic smoke related residue on the paint that I can’t get off. Feels very rough, like sandpaper. Tried a few things, but afraid to ruin the paint. Any thoughts? Thanks.
Old Nov 17, 2024 | 09:21 PM
bigblock427's Avatar
bigblock427
Have you tried to remove it with a clay bar?
Old Nov 18, 2024 | 11:30 AM
Johnf692's Avatar
Johnf692
Thanks for the response. Didn’t think about a clay bar since I was thinking I need to use some type of solvent that will dissolve the plastic residue. I guess I could give it a try.
Old Nov 18, 2024 | 11:34 AM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i know this will sound stupid, but have you tried baby oil? as strange as it seems, baby oil seems to work on a variety of paint surface related issues and it doesn't harm the actual paint finish. another thing that might work without damaging the paint itself is WD40. just a couple of off beat suggestions that most people don't try that do work.
Old Nov 18, 2024 | 01:46 PM
Tampa Jerry's Avatar
Tampa Jerry
You can also try 3M Adhesive Remover. Try it on an inconspicuous place first. You can get it a NAPA or any auto body supply store. Jerry
Old Nov 18, 2024 | 07:09 PM
forman's Avatar
forman
I would try the clay bar first if it was my car
Old Nov 18, 2024 | 07:24 PM
ignatz's Avatar
ignatz
These were all good suggestions to avoid anything that might dissolve your underlying paint. So far as I know, original 69 paint was lacquer and there are solvents which will dissolve it. Any liquid you try should be in another area that won't be noticed.
As to what happened with your fire, it sounds like the plastic burning turned into an aerosol that physically adhered to rather than settled onto your paint. Tough call on that. One would hope there was a residual layer of wax.
You should know that under General Corvette Topics, there is a Paint/Body forum with more experts for your situation. Worth posting there.
Old Nov 19, 2024 | 03:16 PM
Mark G's Avatar
Mark G
How about a [clear] picture?
Best thing would be to find a shop which does custom paint jobs on like street rods and other non-production paint work. I'm sure they'd be able to coach you what can be done. But let's see a picture of the wounded area.
Old Nov 19, 2024 | 04:58 PM
Johnf692's Avatar
Johnf692
Default Paint Question
Thanks to all for your suggestions. First, photos don’t really show residue. It feels like fine sandpaper on the paint, but doesn’t show up in pictures very well. Tried mineral oil, cleaner wax, wd40 and adhesive remover so far with no improvement. Funny, I seem to be able to scratch it off with my thumbnail, but can’t do that for an entire fender. I think the clay bar might work, or maybe consult a paint shop as was suggested. I’ll figure it out at some point, just a lot of trial and error until I hit on the correct solution. Nothings ever easy!
Old Nov 19, 2024 | 08:23 PM
ignatz's Avatar
ignatz
You might try Gorilla tape or something similar. The fact that you can scratch it off sounds like it is not chemically bonded, just "stuck".
Old Nov 20, 2024 | 04:55 PM
Johnf692's Avatar
Johnf692
After a lot of trial and error, and based on suggestions received, I found I could remove the smoke/plastic residue by lightly scraping the fender with my wife’s plastic dish scraper of all things. As was suggested by an earlier poster, it appears the residue didn’t bond to the paint, even tho I could not get it off with any type of cleaner wax, rubbing compound, etc. After lightly scraping the crud off, I polished it up and good as new (as new as 55 year old paint can get haha). Thanks to everyone for their suggestions, that helped me eventually get this figured out.
Old Nov 26, 2024 | 02:05 AM
Tuna Joe's Avatar
Tuna Joe
I use those plastic razor blades for stuff like the op was talking about. They work great and don’t scratch
Old Nov 29, 2024 | 10:12 PM
Mark G's Avatar
Mark G
Great to hear!!
To Paint question
