Ignition key switch action
Old Nov 25, 2024 | 10:43 PM
kansas123's Avatar
kansas123
Default Ignition key switch action
When I start my '72, the key switch does not have much spring-back to it when I release the key. I always thought that it should. Since I know what it is doing, I always turn it back just a bit after starting. Can this be adjusted with the ignition switch, and if so, when I loosen it do I need to push it or pull it down the column to solve the problem? Thanks
Old Nov 26, 2024 | 12:51 PM
sunflower 1972's Avatar
sunflower 1972
https://www.corvetteforum.com/forums...on-switch.html
Old Nov 26, 2024 | 10:03 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
The internal moving parts may be dry/dusty inside.
Follow the metal rod down to the ignition switch. Rotate the key slowly to ACC, then to OFF, then to RUN, then to START.
Let the key return on its own.
Whatever you see moving...put a few drops of 3 in 1 Oil on all the moving parts.
Put a few drops inside the slot that the key fits into also
Rotate the key to all the positions 4-5 times.
Does it seem to have more "Spring-back" in it now when you crank the car and let the key return by itself??
If not then you need to adjust the parts mentioned above in the Shea post.
Old Nov 30, 2024 | 03:04 PM
kansas123's Avatar
kansas123
Thanks! Next 'warm' day I'll try these things. I figure the sector is maybe gummed up or dirty like you say.
To Ignition key switch action
