LS swap engine temps
Old Dec 30, 2024 | 04:27 PM
TorchZ51's Avatar
TorchZ51
Default LS swap engine temps
Curious on comparing engine temps for those that have LS swapped their C3.
Old Dec 30, 2024 | 04:58 PM
Tranz Zam's Avatar
Tranz Zam
I have a few swapped cars. In the Vette it runs about 180ish, unless it's cold out, then it'll be around 160.
Old Dec 30, 2024 | 05:03 PM
ignatz's Avatar
ignatz
Likely LS swaps include the cooling system. My electric fans only seem to come on when I shut off the motor.
The general subject was discussed here
https://www.corvetteforum.com/forums...y-cooling.html
and I posted separately here
https://www.corvetteforum.com/forums...n-my-69-a.html
Here in the California bay area I don't much see really really hot days but when I do its still not a problem
Old Dec 30, 2024 | 05:54 PM
Corey_68's Avatar
Corey_68
LS engines are designed to run a little warmer than a Gen I SBC. Most LS operating temp is around 200-220 degrees, not unusual to see 220-225 degrees sitting in traffic on a 100 degree day with A/C on.
Old Dec 30, 2024 | 08:07 PM
ignatz's Avatar
ignatz
I guess I never really answered the OP's question. I did look up the specs on the thermostat that came with my motor, a 12600171 part #. It opens at 185 degrees. After opening, I would assume it is the cooling system which governs what the motor heats up to.
Despite all the fooling around with underhood air temps in my posts, I never thought to measure my motor with an IR thermometer. My gauge I've calibrated and it always falls in the normal range. Heat has never been a concern.
Old Dec 30, 2024 | 08:54 PM
TorchZ51's Avatar
TorchZ51
160-180 seems low for an LS. Are you using a bypass hose on the water pump to get 180F?
Old Dec 30, 2024 | 09:02 PM
71 Vert LS1's Avatar
71 Vert LS1
On my LS swaps it depended on the radiator size a bit.
On my summer driver LS swaps I run a 180 degree thermostat. ECM set to turn on the fan at 205 and off at 195.
Having said that I run a 195 degree thermostat in my 98 Wrangler with LS6 swap to get more heat in the cab when I'm plowing snow. The ECM is set at 210 on and 195 off.
When I did my 71 C3 LS swap I used a generic LS swap rad. Biggest I could fit. Never had any kind of cooling issues. Single 16" Spal fan.
Keep in mine my stock 2020 Silverado ran at 210 day in and day out.
Old Dec 30, 2024 | 11:59 PM
TorchZ51's Avatar
TorchZ51
Trying to determine if my coolant temps are correct @ 205-215F with 187F Tstat, Champion 3 row rad, and C5 fans. Fan settings are turn on 195 and off at 190.
Old Dec 31, 2024 | 06:42 PM
Tranz Zam's Avatar
Tranz Zam
The engine will be happy at those temps. I set mine up to run a little cooler, but I have one setup running at that temp for years and it's fine.
Old Jan 5, 2025 | 01:02 PM
TorchZ51's Avatar
TorchZ51
I installed a 180 Tstat and temps stay in the 195-200 range now. Set Fan On 200 and Fan Off 190.
To LS swap engine temps
